Blum movento
5/3/23
Travis Alfrey
I have been using Blum tandems for years. Are the moventos worth the extra cost. I would not be using the push to open
5/4/23       #2: Blum movento ...
They have a better weight rating and they are stiffer. But the main reason to use them is the tip on function.
5/4/23       #3: Blum movento ...
Travis Alfrey
And the tip on feature is the press to open???
5/4/23       #5: Blum movento ...
Yes, the push to open feature.
5/4/23       #6: Blum movento ...
Jim Kolar
We have gone to the movento because they have phased out the 569 heavy guides. So many wide drawers now it has become our standard. I do believe there is a noticeable difference in the motion of the drawer and worth the upgrade. I think eventually they will probably replace the 563 with 763 and 769.
5/4/23       #7: Blum movento ...
They are smoother and I use them for large drawers. I've thought about switching entirely to them
6/10/23       #8: Blum movento ...
Joe Folz Member
Do they have to be mounted to the side of the cabinet box or do they offer them in the face frame version?
6/10/23       #9: Blum movento ...
Faceframe overlay you screw the front of the slide to the edge of the FF and you can use a drawer slide stand off or just block it out.
On an inset situation you need to block things out so it's flush with the FF. You also need to use the inset lock so you have an extra adjustment of in and out to fine tune the drawer front with the FF. You can play the game of trying to make it perfect without them, but I've always used the inset locks.
    • Western Dovetail
      Custom Made Dovetail Drawers
    • TradeJobPlacement.com
    • RT Machine Co.
