Gluing doors
6/17/23
Virgil
Glue beads up on my joints after applying. paint
6/17/23       #2: Gluing doors ...
Eddie
Sounds like moisture coming out from the glue. How long do you leave your doors to dry before any sanding, prep, paint?
6/17/23       #3: Gluing doors ...
CRIS
You're propaply getting glue creep. If i had to guess you are using titebond 2 try using titebond 1.
6/17/23       #4: Gluing doors ...
If you are using a water based glue then you need to let the moisture from the glue joints migrate out. Usually a 3 day time at normal shop temps.
I don't have a widebelt so I take them out of clamps and rough sand to 100. Then I'll do something else like build the cabinets for those doors and burn up a few days before I do the final sanding.
If all you are doing is making doors then switch to a glue that uses no water as it's base.
6/18/23       #5: Gluing doors ...
Matt Calnen
I second do not use Titebond 2. What a world of difference that makes. Let your doors sit as long as possible before finishing.
6/20/23       #6: Gluing doors ...
Virgil
Thanks for feed back I'm using titebond original ?
6/20/23       #7: Gluing doors ...
Don't let the glue bead dry on the doors. Cut any squeeze out with a chisel after about 10 minutes. Makes a huge difference in full curing time.
