Compressor tank size
11/5/23
Paul Member
I've purchased an SCM ME 20 edgebander (small entry level edgebander. The specifications for minimum PSI are very clear, but no mention of a minimum tank size. Can anyone offer guidance on the minimum compressor tank size I can operate this machine with? Thank you!!
11/5/23       #2: Compressor tank size ...
You can get away with a small tank like a five to ten gallon. It will cycle more frequently but a 2hp compressor will keep up to the demands.
11/5/23       #3: Compressor tank size ...
Leo G
The don't mention CFM draw?
11/10/23       #4: Compressor tank size ...
Isaac  Member
Website: http://www.milkbuilt.com
Hey Paul,
I'd definitely try to get ahold of someone at SCM and find the spec'd cfm requirements. Are you going to be using the machine for long periods of time? I'm having issues with an old scm widebelt sander that I just purchased. Its got pneumatic tracking on the belt which absolutely drains my compressor and the constant cycling on and off starts to overheat the motor. If you end up going for a smaller compressor, make sure it meets the cfm requirements and/or is rated for continuous duty. Another option, if you don't plan on running the machine for long periods of time, is to buy an auxiliary tank (or scrap an old compressor and salvage the tank). That might buy you some time on smaller jobs. Best of luck!
11/10/23       #5: Compressor tank size ...
duster
I have an older ME15 bander, not sure how it compares to the ME20. The guillotines that cut the banding are the only thing operated by air pressure, so the cfm draw is pretty low.
    • Western Dovetail
      Custom Made Dovetail Drawers
    • TradeJobPlacement.com
    • RT Machine Co.
