Which laser level to buy?
2/23/24
pat gilbert
Which ones are you guys using?
2/23/24       #2: Which laser level to buy? ...
Yavuz Member
Dewalt DW089LG
2/23/24       #3: Which laser level to buy? ...
Yavuz Member
i have both and works great for me.
Dewalt DW0825LG and Dewalt DW089LG
2/23/24       #4: Which laser level to buy? ...
I have a Stabila. When it comes time to replace it, I'll probably get whatever model uses the same battery as my other tools
2/24/24       #5: Which laser level to buy? ...
Been using a PLS 180 for a decade without fail.
2/24/24       #6: Which laser level to buy? ...
pat gilbert
I had a stabila that failed now I have Bosch that is starting to fail
PLS used to be the go to, I guess it is not that important but I do like the 3 plane feature of the Bosch, a finer line would be useful.
The Makita and the Milwaukee and Bosch use a 12v, you would have to get a different battery setup for them
2/29/24       #7: Which laser level to buy? ...
Quicktrim
Have three PLS and a Stabila And a Green Milwaukee.
Hands down the milwaukee is my go to. the squaring lines and micro adjust keep me from needing to set it on a long board to micro adjust. lines are crisp and battery is rechargable.
but PLS is my go to on small jobs as it will stick to a metal corner bead, super handy.
Milwaukee will require a tripod or some heavy steel to get the magnets to stick.
2/29/24       #8: Which laser level to buy? ...
pat gilbert
Does the PLS have the 3 planes feature?
