Draw Bolts
4/4/24
Making a countertop using 1 1/4" thick particle board do you put the draw bolts at a 1/4" from the top surface? as they would be with 3/4" thick tops
4/4/24       #2: Draw Bolts ...
Matt Calnen
I have found it’s better to have them closer to the top surface, usually I do 3/8” from the top surface. Most of my tops are 1 1/4” to 1 1/2” thick. Not sure why that is, as you would think if the joint is cut square it would not matter. It does seem to help the joint draw tighter though. I also use Dominos to help with alignment.
4/4/24       #3: Draw Bolts ...
That is what I was thinking too, thanks Matt
4/5/24       #4: Draw Bolts ...
Quicktrim
I only go as deep as needed to hide the bolt. The closer you get to the surface the more chance you have of a top blowout failure or a crater because of little material below the laminate .
All p lam tops are out of 1 1/8 IPB , so much faster than doing build up and the blanks are only about 35 - 55 depending on length .
4/11/24       #5: Draw Bolts ...
Quicktrim
I have never had that problem, I have done many countertops
I don't usually make countertops 1 1/4 thick, most have been 3/4" thick
    • Western Dovetail
      Custom Made Dovetail Drawers
    • TradeJobPlacement.com
    • RT Machine Co.
