drawer bottoms thickness
11/5/24
gary
How thick are your drawer bottoms? A while back we switched to 1/2" from 1/4". We were making a lot of big drawers so that's when we made the change. Not sure if it is necessary. How big of a drawer do you build with a 1/4" bottom?
11/6/24       #3: drawer bottoms thickness ...
I do 5/8" sides and 3/8" bottoms.
11/18/24       #4: drawer bottoms thickness ...
Bruce
I use 5/8" bottoms. Big drawers, small drawers, doesn't matter.
11/18/24       #5: drawer bottoms thickness ...
I use ¼".
Unless it's something out of the ordinary, the drawer is no bigger than 21" in any direction.
Can't say I've ever done a drawer that was wide and deeper than 21. I might revisit what I use for a bottom if it were 30" deep and 40" wide.
Hardwood parts except for the bottom where I use Baltic Birch.
Undermount slides puts some of the pressure from the bottom directly on the slides too.
12/5/24       #6: drawer bottoms thickness ...
chris
I always use 1/2" plywood UV. is the 3/8" & 5/8" material plywood I assume?
12/5/24       #7: drawer bottoms thickness ...
Yes, Baltic Birch. 9mm and 15mm
1/16/25       #8: drawer bottoms thickness ...
Chris
Solid maple 1/2" sides and 3/8" ply bottoms for large or small drawers
    • Western Dovetail
      Custom Made Dovetail Drawers
    • TradeJobPlacement.com
    • RT Machine Co.
