Large flip up door
2/28/25
Travis
Hi guys. I have a large range hood surround to build that will require a flip up opening front panel that ideally would be 70" wide x 30" tall. This would be made from 1/2" birch ply, with a solid 2 1/4" x 3/4" door frame (basically a shaker door with 1/2" panel). I am looking for hardware suggestions to allow this to raise with lid-stays to hold it. I have looked at Blum Avento but I'm not sure it will work due to the weight. Can anyone suggest a hardware system to accomplish this? Thank you
3/1/25       #2: Large flip up door ...
duster
Aventos will work for this. They come in 4 different weight ranges, and each one is adjustable also. Just installed one with a 78" wide x 18" tall door, we used the one with the second lowest weight rating.
3/1/25       #3: Large flip up door ...
Leo G
Blum has a calculator to let you know if the Aventos will work with your door. Let me see if I can find a link.
3/1/25       #4: Large flip up door ...
Leo G
Looks like the limit is 24" on door height unless you use a split door.
3/3/25       #5: Large flip up door ...
Travis
Leo-I did look at their calculator and saw that my dimensions are outside their limit. I'm wondering how much that difference would matter. I am also pretty sure that I have used a different "lid stay" type hardware from Blum before that was not the Aventos but I can't find any info on it. Would you have another suggestion? Thanks
3/3/25       #6: Large flip up door ...
Leo G
The only thing I can offer is maybe Halefe might have something in their catalog that will do the trick. 30" is probably quite the ways out of range since you are already near the width limit too.
3/4/25       #7: Large flip up door ...
Michael Todrin Member
Website: http://www.todrinfinewoodwork.com
I am just finishing up a project using the Aventos. My biggest door is about 38x26 and I am using the heaviest duty one per the size chart, but with the damping on the soft close lowered all the way. That being said, even though your size requirements are outside the bounds of their recommendations, I would be surprised if they wouldn’t suffice for occasional use. They seem to be heavy duty and well designed.
    • Western Dovetail
      Custom Made Dovetail Drawers
    • TradeJobPlacement.com
    • RT Machine Co.
