Pocket Door Frustrations
4/16/25
Troy Beverly
I currently use Accuride 1332 cable system for the few pocket doors I am asked to incorporate in my projects. I personally think they should be outlawed. Clients do NOT know how to close correctly. If the doors are slid out of cabinet till they stop then user need an addtional firm pull to lock the door into the hardware indent then properly finish closing door. This never happens and hardware becomes damaged and doors don't work right. I researched the Hawa System but cabinet doors do not meet the minimum size most of the time, not to mention the ridiculous cost. Anyone ever use something else that is good quality for higher end cabinetry?
4/16/25       #2: Pocket Door Frustrations ...
I use the rack and pinion ones.
They're still terrible, but slightly less than the cable ones.
I don't know why anyone wants pocket doors on cabinets.
4/18/25       #3: Pocket Door Frustrations ...
John McGinnis Member
Pocket doors are horrible. I like to imagine that there will be no pocket doors in heaven.
4/21/25       #4: Pocket Door Frustrations ...
Todd M Wilde
We ditched the Accuride with cable system, years ago and have since been using the KV 8090 Knape & Vogt). doesn't go out of adjustment like the cable systems do but with incorrect use (premature closing of doors before full extension) the user will still damage the face of the door :(
KV8090
4/21/25       #5: Pocket Door Frustrations ...
Warren Member
bit early to ask, are there going to be live edge tables in heaven or just the other place?
4/23/25       #6: Pocket Door Frustrations ...
Mike D  Member
I feel your pain. Blum is promising a new counter top model next year and Salice is supposed to have a new one "Gravity" for release in July.
Accuride has their new(ish) 1532 which looks promising. But at $1000 and up per door, I am hesitant to "test" it out.
4/24/25       #7: Pocket Door Frustrations ...
Steven
Have used both the Accuride 1432 cable system and Accuride 1234 with follower strip within the past year for pocket doors; KV 8090s in the past too.
The Accuride 1234 part that follower strip attaches to always seems to be bent or machined incorrectly so you have to make sure you don't try to force the follower strip against the edge when screwing or it may pull the top and bottom slide out of alignment when opening/closing.
All recent pocket doors I've done were overlay doors with notches cut in top rail and bottom rail with dado cut in floor of cabinet; a real pain to get working properly.
The most frustrating part is when no matter how much you adjust, the top and bottom tabs don't click onto the rollers at the same time. I like to put the sticker on the door that says the door must be fully retracted before closing or door will be damaged. Also have to explain and demonstrate that they must pull the door firmly until they feel the tabs latch onto the rollers at both the top and bottom before closing the door.
Then, they are responsible for damage if they forget.
5/6/25       #8: Pocket Door Frustrations ...
Ethan
The Accuride 1321, “pro pocket” can handle doors to 24” wide and 42” tall. This system springs the door out to full open position in the last inch or so of travel. The hardware is all behind the door so no worries of door face being damaged. Can also provide an overlay application on the sides.
5/6/25       #9: Pocket Door Frustrations ...
Pdub Member
Pocket Doors - Designer's dream, Cabinetmaker's nightmare. Only sightly higher on the pole than tambour doors.
The KV 8091 is the best currently available for smaller doors in my opinion.
If you're going big, the Salice Exedra is pretty slick. Pretty pricey too.
5/8/25       #10: Pocket Door Frustrations ...
I've got a job coming up I'm going to try the Blum Revego. $1600 a door.
Why do people want this stupid crap?
11/29/25       #11: Pocket Door Frustrations ...
SaraWil1515 Member
Once the stop/lock isn’t engaged, the hardware gets sloppy fast. I’ve had better luck with simpler non-cable setups or push-in magnetic catches that guide the door home without the “extra pull” step. Not as fancy, but way more idiot-proof for high-end installs. If the budget allows, Hawa is excellent — just not practical for most cabinet door sizes, like you said.
    • American Fabric Filter Co.
    • Sandman Products
    • The Millwork Studio
