Cabinet back waste
11/1/25
Keith Farr
Im a faceframe shop using 1/4" backs . I genreate a lot of 16" x96" waste from backs cut for lowers. We save some for drawerbottoms but cut up and discard alot What are yall doing with this waste?
11/2/25       #2: Cabinet back waste ...
james e mcgrew  Member
We order 5 x 8 far less offall
11/12/25       #3: Cabinet back waste ...
Derrek
Website: http://Www.closetdr.com
Years back when I first started building home offic cabinets in our business, we used 1/4” back because, at the time we viewed it as cheaper because it was $2 per sheet cheaper than 3/4” material. The first thing we noticed was the waste, all these odd size pieces to big to throw out but not the right size for anything. Then we looked at part count in the cabinet, case material, 1/4” back material and nailer material. A neighbor shop was proud of how he cut his nailers from “scrap materials “ and it didn’t cost him anything. I asked if he cut it with “scrap labor”.
We switched to all 3/4” materials, eliminated the 1/4” and the nailers, the area we stored the scrap in and reduced the amount of waste we generated and built a better cabinet. Just my $.25
11/13/25       #4: Cabinet back waste ...
Scott Markwood  Member
Website: http://www.hafele.com/us
“Scrap labor” made me LOL, Derrek!
11/16/25       #5: Cabinet back waste ...
Keith Farr
Derreck Thanks for the response. I have thought about this thru the years . Actually did 5/8" backs on a set last year . It was a DIY barndo that the owner had run 2x4 lathe horizontally with no boards falling in my nailers. The units where all small but I wondered how it would affect me on weight when my units got much longer (If it will fit on the 12' frame table we build it) Are you increasing the depth of your upper cabinets to provide same interior depth as before ? Do you ever drill adjustable shelf hole in the backs and increase the length you are willing to span ?
11/29/25       #6: Cabinet back waste ...
SaraWil1515 Member
We run faceframe boxes with 1/4" backs too, and yeah, the offcuts pile up fast. Besides using them for drawer bottoms, we rip a lot of the waste into backer strips, templates, paint shields, and spacers for installs. Anything that’s straight and clean also gets used for toe-kick backing or cabinet stretchers. Still end up tossing some, but finding “shop-use” purposes cuts the waste way down.
