Floating shelves
2/19/26
Travis
We seem to be doing these more and more and have used several different brackets and supports, none of which I've been completely happy with. They always seem to end up feeling "spongy" to me, or aren't long enough to support the shelf depth, or won't hold level, etc. I'm playing with the idea of just using some type or rod or huge bolts or something driven into the studs. Do you have a system or method you've settled on that you'd like to share? FYI our shelves are always torsion boxes, and can sometimes be supported on one end. TIA
2/19/26       #2: Floating shelves ...
Have you tried these? As long as you hit studs they are pretty sturdy.
Floating Shelf Bracket
2/20/26       #3: Floating shelves ...
Travis
Leo-thanks for the response. I have used those, and still am as they do work better than others I've tried. But I have mostly the same issues with them. Installed over drywall, they are spongy. I have cut out the sheetrock and installed directly to studs but that is a mess and still flexes somewhat. Also the longer lengths I often need are kinda pricey.
2/20/26       #4: Floating shelves ...
Can't really disagree with anything you said. The secret is not to crank the screws so hard you crush the drywall behind them. Once you do that it looses the stiffness. And they aren't the cheapest or the easiest to implement.
If you could find studs and put something like rebar into them and keep it straight and level that would be stiffer. But I'll bet it's tough to find studs right where you need them and to drill the holes perfectly the 1st time around.
2/22/26       #5: Floating shelves ...
Will Williamson  Member
A French Cleat, is still my method of choice, I can make that, as robust as necessary.
2/22/26       #6: Floating shelves ...
I have a metal fabricator plas out 3x8 plates from ⅛ steel. Then weld on a piece of ¾" square tubing 90º to the plate.
The plate gets screwed to the side of the stud with 8, 1½ long screws.
Pretty stiff. Not very expensive. Requires opening the wall if a remodel or not a new wall.
I don't have a picture in my phone. I'll try and remember to grab one tomorrow
2/22/26       #7: Floating shelves ...
Found pictures.
2/24/26       #8: Floating shelves ...
Alex_Zhang Member
Website: https://yhcncrouter.com/
Karl, those photos perfectly illustrate why your custom bracket is so solid. Attaching the steel plate directly to the side of the stud is a great way to maximize shear strength and completely bypass the drywall crushing issue Leo mentioned. Welding the 3/4" square tubing creates a highly rigid moment connection that easily eliminates that "spongy" fulcrum effect Travis is dealing with.
Out of curiosity, when the wall is closed back up, do the drywallers just tape directly around the square tubing, or do you leave a slight gap and cover it with the back of the torsion box?
2/24/26       #9: Floating shelves ...
Depends on who's doing the taping. Most of the time my floating shelves are 2-1/4 thick, so theres a fair amount of forgiveness when it comes to that.
2/24/26       #10: Floating shelves ...
Jim Herron
I build mine at 2-1/4" thick with a 3/4" top and bottom with a heavily glued and judiciously stapled 3/4" x 1-1/4" plywood strip placed at the wall edge, set in slight amount so the shelf pulls tight to the wall when installed with a #10 x 4-1/2" washer head square drive screw placed in each stud, before installing 3/4" x 2-1/4" hardwood edging.
This installs as firmly as anything I've tried, especially considering it doesn't require forethought by the builder or opening the wall to install.
2/26/26       #11: Floating shelves ...
Todd Bender Member
I like Karl's brackets.
We use 3/4" all-thread. Drill the pilot hole 1/16" - 1/8" undersized in the center of the stud and drive the all-thread in with a double nut. It's easy to put a torpedo level on the exposed portion and bend it up or down a little to level them. Cut a groove in the drywall behind the shelf to look for wires/pipes. This is the sturdiest and easiest method I've found.
3/2/26       #12: Floating shelves ...
al
Todd,
How deep do you go into stud and how far out from wall?
3/2/26       #13: Floating shelves ...
Todd Bender Member
We'll go 3" into the stud, Al, and leave 8" or 10" sticking out. We take a close look at each side of the wall to make sure we don't hit anything vital.
3/19/26       #14: Floating shelves ...
JM
If we dont have access to the studs before drywall, which seems to be most of the time, we will try to make shelves hollow and 2.5" thick out of 1/2" material. We then take some baltic Birch plywood, cut to just under 1.5" and the length of the stud plus the depth of the shelf. Cut out the drywall a little less than shelf thickness, then PL and screw the strips to the side of the stud. Shelf then slips over baltic strips, and the shelf thickness covers the hole in the drywall.
Sorry, this was really hard to try and explain, but its actually pretty simple and very strong once the PL cures. Similar idea to the steel brackets Karl shows, but we are using plywood on its side for stiffness and doing our best to avoid a drywall repair.
3/27/26       #15: Floating shelves ...
David William  Member
For truly solid floating shelves, try heavy-duty threaded rods or steel dowels anchored deep into studs with epoxy, they eliminate that “spongy” feel. Make sure rods extend at least 2/3 the shelf depth. Use a tight-fitting torsion box sleeve and a precise level during install. Also consider concealed steel bracket systems rated for higher loads, they’re often more reliable than standard hardware.
    • Western Dovetail
      Custom Made Dovetail Drawers
    • TradeJobPlacement.com
    • RT Machine Co.
