CUT VENEER ON CNC
6/9/26
JOHN ALLAN Member
Website: http://arkansawooddoors.com
We mfg veneer raised panels for cabinet doors. Past years we cut our veneer to size manually using large paper cutters. Due to loss of my veneer face supplier we are forced to purchase our veneer a 48" x 55" size faces. My plan is to cut our veneer faces to size on our 4X8 Thermwood, using our nesting software. Plan is to use 1/16" down shear bit, veneer held in place on spoil board with our vacuum system.
Anyone had experience doing this, suggestions welcome
6/9/26       #2: CUT VENEER ON CNC ...
No experience. Would a drag knife work better?
6/10/26       #3: CUT VENEER ON CNC ...
I have tried this with limited success. What is the format of your veneer? If it is unbacked you are going to have problems with vacuum hold down. Particularly with open grained veneer like oak. Even backed veneers will curl up - there is so little force holding veneer down. I recall standing by with a roll of masking tape to be able to hold a piece down mid cut. The dust collection shoe can drag the veneer and shift its location and also the offcuts can foul the cutter so try without DC and shoe.
I have used a drag knife with better success mostly for fancier work like herringbone or diamond match faces. It is faster and you get cleaner edges but you have to be careful of the final corners where the cut pressure can tear off a chunk of veneer. I think I have done two passes with the drag knife sometimes with fragile woods like curly maple. It takes full attention so that you can stop the cut when the veneer lifts off the table. It is a fast way to make scrap.
    • TradeJobPlacement.com
    • Country Saw and Knife
    • Cabnetware Support
    • Denray Machine
    • WalzCraft
