Computer Aided Design
Subject: Re: Should I upgrade to CV8?
7/19/13
PWW Member
To all CV users
I am currently running 2011 R1 and am doing fine with it. Vero (or whoever they are these days) is running a special for me to upgrade to the newest version 8 and save a decent chunk of $$ because it has been so long since I renewed. It's still going to run me about $1k. I will be adding CNC in the not too distant future and if I stick with CV (as opposed to switching to Mozaik), they'll get that money from me anyway.
So, how do you all like V8? From the forums, it sounds like maybe they are trying to concentrate on fixing the bugs? Is it crashing more frequently? I know there was a problem with wireless Logitech mouses (yep) and I'm loathe to give up the mouse I am so used to.
All opinions are appreciated.
7/19/13       #2: Should I upgrade to CV8? ...
ranliker
From 5.0 I skipped v6 and spent only a small amount of time in v7. I've been running v8 build 133 with very few problems and really like it. I don't remember enough of v7 to tell what additional features v8 has for you. So I'd pin the salesman down for that.
I see Logitech mice are still listed as causing issues, but I'm running two logictech trackballs without problems. For me their aren't many, if any, bugs that cause any hang-ups. There are six of us here, without CNC.
7/19/13       #3: Should I upgrade to CV8? ...
Dave
They have just released build 138 of CV8 -don't think there are many bugs at all left!
CV8 is the best yet-you should definitely upgrade!
7/20/13       #4: Should I upgrade to CV8? ...
Jonah Coleman
Well there are plenty of bugs left, but that's any software. Real question is whether they are bugs that affect you or not.
You're missing the CAM editor, for one thing. I absolutely love it. But yes, V8 is my favorite so far for sure.
Here's the what's new for the versions you've missed:
Assembly Level
Specify and Configure Sliding/Bypass Doors
Create Assembly Sheet 3D Views Per Assembly
Assembly Parameters Added to Assembly Level Views
Assembly Wizard
Specify Custom Line Bore Spacing
Specify that Applied Doors/Applied Ends Sit Outside Object Space
Control Sliding Door Quantity, Overlap, and Stagger
Divider Part Specification
Specify that the Face Frame Sits Outside Object Space
Bid Center
Report Variable
Per Shoe Cubbie Bid Method
CAD
Symbol Selection moved to Sidebar for easy Drag and Drop Placement
Updated CAD Image File Selection for All Supported Image Formats
Remember Last File Path for Inserted CAD Image
Counter Tops
Rough Splash Part Added to Counter Tops Material Schedule
Doors
Specify and Configure Sliding/Bypass Door Hardware
MDF Doormaker Horizontal and Vertical Slats Show Visually
Set Default Door Profile by Door Style
Set Default Door Material by Door Style
Drawings Area
Set Section Percentage for Assembly Sheet End Views
General
Control Frequency of Curve Tessellation Lines
Room Selection Via 3D View
Room Selection Via Reports and Order Entry View
New Room Option Via Reports and Order Entry View
Job and Room Property Available in Reports and Order Entry View
Job, Room, and Assembly Parameters Visible Via Reports View
Pass Parameters and Their Values Via an ORD File
Selected Constraints More Visibly Obvious
Option to Remove Constraints
BidData.mdb Optionally Generated from Transmit to Factory Option
Layers
Display Annotation to Show Drawer Quantity Visually in Plan View
Enable/Disable Tessellation Lines
Accessories Layer to Control Accessory Classed Item Visibility
Layout (Room) Level
Wall Layout via CAD Tools
To Drawing Via Right Click Wall in Elevation Menu
To Live-Drawing Via Right Click Wall in Elevation Menu
Specify End of Wall Clearance
Specify End Wall Clearance
Parts
Define Machining Operations Via New CAM Editor
Edgebanding Follows Edge Miters
Select Added to Right click menu for Edit Splits
Reports
Display Empty Report on Report Center Entry (Speeds Up Initial Report Center Loading)
UCS
Define Line and Arc Route Operations
Assembly Level
Control Left and Right Drawer Side Clearances Individually
Take Part to Part Level From Reports View
Edit Part Properties From Reports View
Assembly Wizard
Combine Nailer Back Dados Into Bottom/Deck
Combine Nailer Back Dados Into Top
Additional Line Bore Rows in Ends/Partitions Based on Width Spacing
Line Bore For Backs
Line Bore For Clipped Backs
Bid Center
Bid Report Cabinet List Report Variable
Bid Report Cabinet List with Prices Report Variable
Option to Estimate Sheets of Material Used with Generic Optimization
CAD
Free Hand Revision Cloud Option
Pre-formatted {dim} Automatic Text Parameter
{value} Automatic Text Parameter
{system.time} Automatic Text Parameter
Show Modular Catalog Options in CAD Tables
Modular Catalog Options in Assembly Level AutoText
Doors
Mirror Door Style Tool in the Door Catalog
General
Create and Output Part Sheets (Similar to Assembly Sheets)
Define Dimension Prefix, Suffix, and/or Alternate Units
Test Constraint Text Parameters
Matrix Pricing Attached to Parts Included in Setup Packages
Overwrite All Options in Setup Package Utility
Use Modified Job/Room Construction to Overwrite Existing or Create New System Methods
Render Mode Selected for All Views Remembered After Exiting
Ability to Define Choice Lists for System Parameters
Delete Confirmation Window at Order Entry
Option to Display Counter Top Depth Dimension Against Wall
Layers
Part Sheet Layer
Layout (Room) Level
Enable/Disable Option to Center Appliances Under Windows
Show/Hide Walls Option to Show/Hide Multiple Walls
Display Door Swing Annotation As Single Lines
Parts
Increase/Decrease Price Matrix Prices by Percentage
Work Plane Selection in CAM Editor Remembered After Exit
Report Center
New Material Summary Report Which Estimates Sheets of Material Used with Generic Optimization
UCS
UCS Selection Screen Remember Column Width Changes
Cursor Focus on Name Field Initially Upon Entering UCS Wizard
Add Section Dividers to Ease UCS Organization
Assembly Level
Place Shoe Sections (Cubbies) in Cabinets
Assembly Wizard
Define Vertical Construction Bore Position for All Construction Boring Types
Option for First Construction Bore Be Fixed Distance on Backs
Define Shoe Sections For Cabinets
Define Back to Back Construction Boring
Finish Button Always Available When Editing a Construction Method Branch
Bid Center
Improved Filter Interface
Bid Report Variables
Accessory List
Accessory Prices
Labor Body All
Labor Body
Summary
CAD
Double Click On Screen Where CAD is Available Takes you Directly Into CAD
Doors
Increase Door Price Matrix Prices by a Nominated Percent
Set a Minimum Door Cost by Material
Drawers
Blind Dadoes
Dado Fit Adjustment
Drawings View
Title Blocks Can Be "Set As System Defaults"\
Selecting a Different Title Block Will Replace the Current Title Block on the Drawings Page
Print Current Page for Drawing Sheets
General
ORD File Format Include Property Definition Per Custom Cabinet
Part Level Access for Solid Drafter, Solid Standard, and Solid Advanced
Automatic Lighting
Global Illumination Radiosity Rendering
Option to Re-render on Lights, Finish or Texture Change
Selected Path Displayed In Object Tree and Can be Copied to Clipboard
Simplified Style/Equation Definition in Object Tree Parameter Editor
Photovision Render Process Speed Improvements
Job Properties
Combined Door and End Panel Selection onto Doors Tab
Simplified Door Style, Material, and Profile Selection for Doors
Layout (Room) Level
Edit Part Shape from Room Level
Save and Recall 3D Views per Job
Expanded Favorites Bar from 16 to 32 Objects
Create and Edit Basic Ceilings
Create New Finishes in 3D View Colors Area
Improved Room Rename Speed in Job/Room Properties
Plan Right Click Section Option Changed to Activate "Edit In Place"
Scroll Zooming in 3D View Zooms on Cursor Location
Material Catalog
Control Slot Offset for Sliding Door Hardware
Parts
Set Parts to Ignore Grain for the S2M Center in the Part Catalog
Expanded Automatic Part/Operation Dimension Options
Report Center
UCS
Process Variables In-Line
DNDFLIP Parameter
_EDGnEXT Parameter
_EDGBEXT Parameter
_EDGLEXT Parameter
_EDGREXT Parameter
_EDGTEXT Parameter
_ELEADJ Parameter
_LEADEDGE Parameter
7/21/13       #5: Should I upgrade to CV8? ...
cabinetmaker
Yes, upgrade to CV8, Ultimate. I would lose it if we tried the things we do daily with just advanced or standard.
Anyway, I bought S2M and upgraded to CV8 @ the same time, it was steep learning, but the support is there. Buy some training while you are at it.
cm
7/23/13       #6: Should I upgrade to CV8? ...
PWW Member
OK, I'm likely going to do it. I just read a lot of posts on the forums about crashing. However, it seems a lot of those are due to the Decorative catalog maybe?
7/23/13       #7: Should I upgrade to CV8? ...
Jonah Coleman
Website: http://www.fletcherwoodproducts.com
Seemingly most people reporting crashing are running Windows XP. Apparently if you turn off the origin indications in each view the crashing goes away. I think they thought they fixed that in a build, but people still report it.
I hardly ever have crashing. Your mileage may vary.l
7/23/13       #8: Should I upgrade to CV8? ...
cabinetmaker
We have some crashing, and we run xp pro. But, it's not very much
7/23/13       #9: Should I upgrade to CV8? ...
Dave
Windows 7 pro
network version
Hardly ever crashes [once a month?]
7/24/13       #10: Should I upgrade to CV8? ...
ranliker
I didn't specifically address crashes in my post above. Very rare for me. Currently I have CV running only on Win7 machines. But until I just recently upgraded my computer, a Dell, year 2006, to Win7, I had it running on WinXP Pro with no issues.
7/29/13       #11: Should I upgrade to CV8? ...
I work for one of the largest closet companies in the midwest and we use CV 7 and 8 and crash all the time in 8 in Reports if we don't copy the rooms first. We also use Macs. CV is aware of the problem and are suppose to have a fix soon
7/29/13       #12: Should I upgrade to CV8? ...
cabinetmaker
you need to upgrade to cv8 ultimate to get all the bells and whistles. It's worth it
