Computer Aided Design
Subject: Re: Acad- drawing in inches, dimensions in millimeters
11/7/13
Is this possible? How?
Anyone have a file with layers they would be willing to send me?
Creativecustom@comcast.net
Thx. Mike
11/7/13       #2: Acad- drawing in inches, dimensions ...
Alex
Just modify your dimension style(s):
Unit format: Decimal
Precision: 0.0
Suffix: mm (if you want to show the units)
Scale factor: 25.4
You could also add alternate units to show the inch equivalent if you wanted, or keep primary units in inches, and set alternate units to millimeters... with the appropriate scale factor (1/25.4)
Easy peasy...
11/8/13       #3: Acad- drawing in inches, dimensions ...
Thanks for your help! I'll give it a whirl
11/14/13       #4: Acad- drawing in inches, dimensions ...
Jon Andrew Member
Website: http://www.cad-condesign.com
Also, you can change it to show Dual Dimensions in Metric and Inches. We have a client in Canada that we did this for. But, the only thing that might bite you later is the change over. Our client in Canada had very specific numbers they rounded to to built what we drew. For instance 2'1" = 636 mm, Where they wanted us to round down to 635 mm. Then for 2'5" = 736 which they wanted us to round up to 737 mm.
11/22/13       #5: Acad- drawing in inches, dimensions ...
Thanks guys.
Im having a bit of trouble.
I set it up and put the alternative units, but if my dimension is 606.60 mm, the alternative unit is 609 19/32, when I want it to say 24".
How do I fix? Thx!
11/22/13       #6: Acad- drawing in inches, dimensions ...
Also, i would like to draw in inches and have it dimension inches and mm
11/22/13       #7: Acad- drawing in inches, dimensions ...
I got it
11/22/13       #8: Acad- drawing in inches, dimensions ...
Now, what if i want to draw some circles in mm as in a 5mm hole, but want to dimension it in mm and draw the rest ofvthe job in inches? So i would draw 5mm line bore and then toggle back to my current settings to dimension it in both inches and mm.... How?
Thx
12/6/13       #10: Acad- drawing in inches, dimensions ...
vmdcad Member
Hi All,
I found here some discussion regarding Auto Cad, If you want more discussing & better solution, visit to the below link. It will be more easy to contact them and send your problem details to get solution online.
Format Conversion
2/13/14       #11: Acad- drawing in inches, dimensions ...
Michael Member
Be careful drawing in inches and then sending the shop drawings in mm. Autocad rounds off when dimmensioning and over ten feet you can lose mms causing cutlists to be incorrect relative the actual space. I highly recommend drawing in mms and showing the client the drawings in inches while maintaining the integrity of mm distances/dimmensions for shop drawings and cutlisted parts.
Clients won't miss a mm here and there but the shop will.
5/27/14       #12: Acad- drawing in inches, dimensions ...
spartan Member
Michaels warning is dead-on. Don't ignore it. Trust me .. its a problem that no-one will notice until you are installing.
