Computer Aided Design
Subject: Re: CUT LISTING
CUT LISTING
3/23/15
Matt  Member
Hello All,
I am working with a company that cannot afford to buy the overpriced microvellum (my opinion). Is there anyone out there still using excel cutlist for standard cabinets? I know there are cheap programs out there and I have tried a couple. They were not worth the trouble.
All they need is cut sizes. They do not need edgband instruction or machining info.
3/24/15       #2: CUT LISTING ...
Gary B.
Hi Matt,
No doubt Microvellum is expensive; but you get what you pay for. Microvellum will do much, much more than a simple cutlist. If that is truly all you need, it would be simple enough to create a template in excel that used vlookup formulas and simple sizing formulas. If you're willing to spend some time at it, you could probably have exactly what you want within a few hours or days (depending on your excel proficiency). Youtube is a great way to learn about excel formulas. Roll up your sleeves and make what you want.
3/28/15       #3: CUT LISTING ...
Brian
As a Microvellum user for years I agree with the previous post. Microvellum is powerful. Yes if all you are looking to do is create cutlists for box cabinets use Excel, if Excel has you stumped you do not want to go anywhere near Microvellum. You can do a fantastic automated cutlist in Excel, If you need help with getting started in cutlisting with Excel drop me a note and I will see if I can help.
3/28/15       #4: CUT LISTING ...
Samuel  Member
You can use a free program called Maxcut v2 you can use the free version for a free program its a very organized system. It gives you your cut list and materials and how many sheets are needed, you can add hardware, edging, costs, invoicing, project summaries and more you should check it out.
Maxcut v2
4/7/15       #5: CUT LISTING ...
Les Eversen  Member
Website: http://www.cadcode.com
Hi Matt. Cutlists are generally only one step along the way to what comes next. If you build a standard line of cabinets and only need to count the quantities of the parts of a given size, then you should be able to do that in a spreadsheet. But if you're then going on to actually cut the parts, you'll need optimization software. Depending on the type of saw you use, a free program might cover it or you might benefit from paying for one that really drives the saw to its maximum potential. If you're nesting, then you definitely need a competent program. So what's the endgame here?
4/8/15       #6: CUT LISTING ...
yaakov
polyboard have low level license
that is very powerfull with cut list
without pp
1/4/17       #7: CUT LISTING ...
Don Caron
C++
