Computer Aided Design
Subject: Re: Semi-Automatic Cut lists
4/11/15
Gavin Member
About a year and a half ago, I posted a question to this forum regarding generating cut lists from solid 3D models. A gentleman with the user name ‘splinter’ on this forum took up the cause and developed an application that showed great promise. Unfortunately, because I had an Apple, and he had a P.C., it ultimately never reached fruition.
Not to be dissuaded, I wrote the lead developer of a program I use called ViaCAD, and asked him if he would be interested in extending the bill of materials module of that program to solve my problem. To my surprise, he obliged. There were a couple bugs, but now the latest beta of the ‘pro’ version of ViaCAD seems to be working.
The program takes the x,y,z extents of solid objects, and names the largest dimension length, the second largest width, and the smallest thickness. Objects are then further classified by name. Example: 5 objects that have the same name and dimensions will appear as one record with a quantity of 5, regardless of which way they’re oriented (as long as it’s along an x,y,z axis). Objects with different names, but identical dimensions will create their own records based on the name field.
I import my model into the program in .dwg format, then name my parts (hiding them after naming, while they’re still selected, works well to keep things organized). Then I export the results in a tab delimited file which can be picked up by Excel for further organizing.
Things to watch out for: objects at odd angles won’t report correct values. Objects which are ‘wider’ than they are ‘long’ (with grain), will have the length and width fields reversed.
The capabilities of the cut list function aren’t earth shattering, and likely won’t interest many here on this forum using industry specific software packages. The function is inherently ‘dumb’ in that it has no accommodations for the concepts of grain, or for objects not oriented on one of the three major axes. Also, it doesn’t have a material parameter. However, for any small potatoes out there, like myself, who just directly model things, and then want to leverage the model to create the cut list, it will likely be helpful.
To be clear, I have no relationship with ViaCAD besides having them pursue my request. For 2D drafting, I find it a capable program. For 3D modeling I prefer a different program, although I still do some edits in ViaCAD. It also has a 3D to 2D function which I find very useful.
I hope someone finds this of interest.
