Computer Aided Design
Subject: Re: Microvellum Machining Hole in custom part
10/18/16
Frank Member
Microvellum allows you to create a product from a 3d object. For instance, if you had a custom odd shaped part, you could draw it in autoCAD or Inventor import it and give it a product number, material and send it to the CNC machine, which is pretty handy. My question is, is Microvellum capable of pocketing out holes/circles in the middle of a part. I extruded a rectangle with a circle in the middle and it did not pocket out the circle in the middle of the part, instead it nested the circle somewhere else on the sheet. Can Microvellum pocket anything? I see a pocket router checkbox in the tool file interface but it doesn't seem to help. Any input would be appreciated. Thank you
10/19/16       #2: Microvellum Machining Hole in custo ...
Clay S.  Member
Website: http://www.microvellum.com
Hi Frank - Yes, our solid model analyzer (SMA) tool allows you to import solids from other software or even create 3D solids in AutoCAD and convert them to CNC machine-ready products. It's great for quick one-off parts or even complicated products with multiple parts and machining. Recognizing a cutouts, pockets, drilling, etc is one of the basic functions of this tool. Keep in mind one thing though... SMA only does what you tell it to. If a hole is on a 3D solid part, it will cut it out. If it finds 5mm holes on the 3D solid, it will look to your tool file and find a 5mm drill to assign to that machining. If it recognizes a pocket, it will choose a router that best fits the diameter of the pocket. Did you create the 3D solid in AutoCAD or did you import it from other software? If you are having difficulty getting it to work as you would expect, I suggest that you reach out to our support department. They'll get things sorted out for you. Feel free to message me if you have further questions.
10/19/16       #3: Microvellum Machining Hole in custo ...
Frank Member
Hello Clay! Thank you for the response. Yes I did draw the part in AutoCAD and later in the day yesterday I got it to successfully pocket out the desired hole. I just had to pull the circle through the 3d part and the program did the rest like magic. Thanks!!!
10/19/16       #4: Microvellum Machining Hole in custo ...
Clay S.  Member
That's great! Glad you got it sorted out on your own. By the way, have you used the PRESSPULL command before? Doesn't work so well with pockets, but if you are creating a 3D solid with machining going all the way through the part it works great. Try it: Create a rectangle for the part. Draw a couple circles, a rectangle cutout or two within the part. Then, type "PRESSPULL" in the command line. Select somewhere inside the rectangular part, not within the cutouts, and pull up to the desired thickness. You can also just type a thickness, like ".75". The part gets created and then you just have to analyze it. The software figures out the rest and applies the tooling.
