Computer Aided Design
Subject: Re: Microvellum Cabinet/Material Weights lbs.
12/6/16
Frank Member
Was curious if anyone out there knew of a way of getting the program to spit out weight for cabinets?? I could have sworn I saw something in the program that asked about a weight of a material. This would be extremely useful to estimating shipping costs. Does anyone know if this feature exists? Thank you
12/8/16       #2: Microvellum Cabinet/Material Weight ...
I don't know about MV but Auto Cad will do it.
Use massprop at the command line then high light what you want to measure.
I'm using Auto Cad 3d. I don't know what MV outputs. So this may not work for you.
12/9/16       #3: Microvellum Cabinet/Material Weight ...
Brian
I am with you in that at one time I thought I was an entry for the weight of a cabinet but now I cannot find it. Looked through the database and I did not see a field where the weight would be so maybe I am mistaken. Have you looked in the reports to see if one existed? That would be a tip off.
12/9/16       #4: Microvellum Cabinet/Material Weight ...
Frank Member
Pat, the AutoCAD tool didn't seem to work for me. Brian, if you open your global settings in FaceFrame Library, under the Job Set-up Variables tab is a Material Weight. Unfortunately it seems to only be for hardwood and I have no idea how it actually correlates with the rest of the software. I checked every report and I didn't see one that said anything about weight-although there may be a work around or some type of command you can set-up in a custom report to see that information.
12/9/16       #5: Microvellum Cabinet/Material Weight ...
I think it only works with 3d solids.
