Computer Aided Design
Subject: Re: ecabinets
ecabinets
4/10/17
majasticwoods
I'd like to here from ecabinets users using ecabinets exclusively for their cabinet design/cnc software.
4/10/17       #3: ecabinets ...
I had to go to CV for commercial reasons, some of which have been now solved in ecabs, but I cut up millions of dollars of work with ecabs over a 7-8 yr run. If I were only doing residential, I would probably still be using it.
4/12/17       #4: ecabinets ...
Stuart Douglas Member
We use it in our custom shop and it is pretty handy. The only thing I can't stand about it is that the Line Drawing Editor is almost useless for shop drawings if you are used to any other software, including ACAD. We do shops in Micro Vellum because we had that software first. The LDE is clunky and not full featured. The rest of ECabS is very good.
7/7/17       #5: ecabinets ...
Gerry Member
We dowel and confirmat our boxes. We use the router to drill the gables and use a 32mm boring machine to drill the horizontals. Ecabinets has no built in mechanism to accommodate 32mm boring, you need to place each hole by hand and then constrain it from the front, back and top or bottom or another hole. Quite a PIA if you are doing a lot of custom sized cabinets. Other than that it works well for us.
7/8/17       #6: ecabinets ...
David Egnoski  Member
Website: http://www.richmondcabinet.com
Not quite true, Gerry. You can position rows of 5mm holes based on distance from deck and distance from front. By placing a shelf, all the system holes are inserted. Not fully automatic but only takes one setup that can be applied to all your cabinets.
7/8/17       #7: ecabinets ...
Gerry Member
Hi David,
I am referring to holes for construction and it seems you are referring to shelf holes. Yes Ecabinets does accommodate shelf holes at a defined spacing.
Ecabinets seems to ignore the part of the industry that uses dowel and confirmat assembly. They do blind tenon butt and pocket screw but have no easy way to drill for dowel assembly on 32mm centers.
7/8/17       #8: ecabinets ...
Gerry,
I agree about the construction boring. I think their methodology is based on supporting their 3 axis router which doesn't do horizontal boring easily. They do offer a number of other assembly techniques as you pointed out.
