Computer Aided Design
Subject: Re: draftsight
draftsight
4/22/17
exhibitman03 Member
Does anyone know what the problem could be getting draft sight to communicate to router via dxf files? I've tried everything, groups, weld, etc. Nothing seems to work. Sometimes the files will work fine, sometimes they won't. Im at my wits end! Thanks!
4/23/17       #2: draftsight ...
Did you try different versions of DXF?
4/24/17       #3: draftsight ...
W. Hagan
Website: http://laurelmillwork.com
Use PEDIT - M (Multiple) - J (Join)
After joining, you can reverse direction - R (Reverse)
We have no issues with DXF/CNC using this method.
4/29/17       #4: draftsight ...
Brian
A little more information please. so you are generating geometry in Draftsight right? What are you using to generate G-code?
5/1/17       #5: draftsight ...
W. Hagan
We're using CADCode to generate G-Code from .dxf exported from Draftsight. The Professional version of Draftsight has a G-Code generator, but I have not used.
5/1/17       #6: draftsight ...
exhibitman03 Member
thank you W.Hagan, Worked perfect!
