Computer Aided Design
Subject: Re: Import V carve desktop models into Alphacam
12/11/18
Ian
has anyone imported 3d models from vcarve into Alphacam? I am new to vector machining,not quite sure what difficulties I would encounter doing this.
12/12/18       #2: Import V carve desktop models into ...
james e mcgrew Member
There was a relationship between alpha cam and Aspire sometime ago, not sure how that would work, any 3d file one would use in VCP would first be a Vectric file or .stl , .obj file ext see if Alpha cam will import Stl or OBj not sure about a vectric file direct.
12/12/18       #3: Import V carve desktop models into ...
I have done a project that way starting with Aspire. I can't remember the procedure exactly, probably an export from Aspire and then import into Alphacam. I bring a variety of solids from other programs, mostly AutoCAD and they all go pretty much the same. No issues that I remember.
