Computer Aided Design
Subject: Re: Autocad function
Autocad function
8/21/19
I’m using acad 13
I have a radiused wall drawn and i used my flat back tape measurer to get an approx location of the outlets on the wall.
What function do i use to draw a line a specific length in an arc So my dimension off the right wall is 149-1/2 on a wall with a radius of 138-5/16”
The overall length of the wall is 295 21/32.
Am i making sense? I can’t just offset the lines, because that’s based upon straight lines, where measuring along the radius of the wall, I need to place outlets at a specific length following along the curve
Thx
8/21/19       #2: Autocad function ...
The length of the chord is 242-1/2 and the height is 71-3/4”
8/22/19       #4: Autocad function ...
Mark R Member
Follow this to lengthen/shorten an existing arc.
https://www.qdoscc.com/blog/autocad-how-construct-arc-specific-length
C
lick near the end of the arc to determine the direction.
8/22/19       #5: Autocad function ...
I don’t need to lengthen or shorten the arch, rather i need to place lines along the actual arced line, to show where the outlets and switches are at. I have a flat back Fastcap tape measurer that i laid along the curved wall and now need to place lines at those dimensions
8/22/19       #6: Autocad function ...
Mark R Member
You're putting field dims to drawing? Thought you needed to do this.
View higher quality, full size image (1216 X 868)
8/22/19       #7: Autocad function ...
Either my length of chord is incorrect or the way you have it drawn is. That 149-1/2” dimension should be about center. The arc is not a semi-circle.
Never the less, yes, that is what i need to do, so maybe I was mis understanding u.
I need the 149-1/2 dims, then need to come back 4-1/4 for the outlet cover plate
I’ll have to copy paste the URL you noted on my laptop, because it’s not a hyperlink on my phone.
Thx!
8/22/19       #8: Autocad function ...
Mark R Member
Yeah, so concept good. Copy your drawn arc and use the Lengthen command from the Modify dropdown. Don't select anything until you hit T for total and enter 149.5 for new length, then select the left side of the copy ... done. Repeat for 144.25 and you'll have both sides of the box.
8/22/19       #9: Autocad function ...
Mark R Member
Oops, 145.25
8/27/19       #10: Autocad function ...
David Wishengrad
How painful, that something so easy is not properly explained. I have no idea what he is asking.
Draw it on paper, take a picture, and upload it.
