Computer Aided Design
Subject: Re: Router Cim Import
Router Cim Import
2/19/20
Jon Daniel Member
I am finishing up a project which imports a spreadsheet to Router Cim. The drawings are in a master folder with no sub folders. I would like to break up the near 600 drawings into subfolders that Router Cim will see so the import finds them automatically, and we can grab the drawings later to run parts that are short in production. Looking to make the forest easier to see in. I cannot find the switch to include subfolders on the import. Any suggestions?
2/19/20       #2: Router Cim Import ...
Dan
From my experience with R-Cim, the user can set a path to the part drawing location. If importing a spreadsheet, the partname in the spreadsheet should contain the subfolder the part is in, along with the part file name.
For example, The path in R-Cim is set to "W:\BOM\". This is only the path to the location of part files main folder. (Do not include sub-folders here.
In the spreadsheet that is imported the partname, should include the subfolder(s) and part file name. The part file being imported will look something like this. "Customer\JobNumber\PartsFolder\PartName.dwg"
When the spreadsheet is imported to R-Cim, the R-Cim "W:\BOM" path is added to the beginning of the spreadsheet part file name "Customer\PartsFolder\PartName.dwg"
The result will be in the Full Path to Part column and look something like this:"W:\BOM\Customer\PartsFolder\PartName.dwg"
Also note, R-Cim does have a limit on the length of a part name which includes the path.
    • Cabnetware Support
    • CabinetCRUNCHER
    • The Millwork Studio
