Computer Aided Design
Subject: Re: Cabinet ware key issues
6/20/24
Joseph
I have had Cabnetware design/ manufacture software Since 97.
All of a sudden my program does not recognize the dongle. I tried reacing out to planit and they dont support that software anymore.
There used to be someone out there that could write around the dongle.
Any help would be greatly appreciated :-)
Regards
6/20/24       #2: Cabinet ware key issues ...
David Wishengrad Member
Try installing a different printer port card in addition to what you already have and the drivers for it and doing a fresh install.
6/21/24       #3: Cabinet ware key issues ...
Adam B
I believe this is what you are looking for.
https://www.designsbydiebolt.com/About_Me.php
6/21/24       #4: Cabinet ware key issues ...
Adam B Member
Here is the correct link
https://forum.designsbydiebolt.com/viewforum.php?f=23
6/22/24       #5: Cabinet ware key issues ...
Good mention Adam, but it appears Joseph didn't check back.
One of the options he refers to is "paid memebrs" will be given a referral to an outside source and there is a 350 charge.
The hacking groups don't like companies charging others for such services. The company they are recommending to make a software backup of a licenced dongle was probably the Canadian company that got hacked. Their source code was accessed, downloaded, fixed and made to work much better and released for free to the general public.
Unfortunately, both, the much better hacked and free version and the paid for versions requires a working installation and dongle and Joseph doesn't have that atm. That's why I first recommended Joseph try to VM a new installation to get the dongle working again temporarily so his dongle info can then be backed up and replaced with a "software only" solution.
From what I can tell, his dongle or printer port is broken or having an irq conflict or similar. If he can get it working, even in a VM, then he has a shot. Also, if his dongle is good, he might be able to send it to them and they probably already have an installed version of CW there to create the patch.
Crypkey may be that company. I cannot remember. They probably charge more now. Joseph can look them up and talk with them directly and ask them himself.
9/11/24       #6: Cabinet ware key issues ...
Joseph
Sorry i looked at the first couple. I did contact Diebolt but the total cost to have support and to make a dongle came close to 700 or so. Then I am not guaranteed it will even work. Looking for a different solution.
Thanks to all I really miss Cabnetware :-( Kind Regards, Joe
9/13/24       #7: Cabinet ware key issues ...
David Wishengrad
Joseph, your comment lacks specific details. It can easily cost a company about $1000 in time to work with someone on something like this.
Old operating sytems that can get on the internet and on the business network are a major security risk.
If this is an off line machine, either the machine is broken, the port is broken or the dongle is broken, as I see it. I don't think you need to get on the internet to activate your dongle.
You should be able to reinstall CW on another suitable machine (even a virtual machine) and identify what, if anything is broken. If it is the dongle you might want to try Northridge Fix.
Good luck. Hope it gets easier for you or you find something else that works to your needs.
    • Cabnetware Support
    • CabinetCRUNCHER
    • The Millwork Studio
