Computer Aided Design
alpha cam nested sheet re ordering
4/20/17
kainan k
I would like to see if it is possible to select the cutting order of nested sheets. Not the parts within the the sheet but the entire sheet itself.
5/21/17       #3: alpha cam nested sheet re ordering ...
Jeff O'Dell  Member
Website: cncwoodworking.net
Sounds like your post outputs all sheets as one program.
One way would be to split the sheets into separate nests and output each as a stand-alone program. Use Nest|Split Nest|Save Sheets to Drawings.
There is also a newer setting in Nesting Parameters called "Minimize Sheet Patterns" that will make several sheets of the same nested pattern and these will be arranged with similar/identical sheets being cut sequentially, which may solve your problem.
