Computer Aided Design
Changing doors reveals in Cabinet vision
6/13/19
Maxi Member
I have issue with reveals in cabinet vision 11 closet setting.
Somehow, I can’t change reveals for closet catalog. Looks that option is locked. (Whatever I try to change that setting coming back. That issue was just with closet catalog. for cabinet catalog I don’t have that problem (Room setting reveals showing fine) Any idea how I can fix that?
View higher quality, full size image (447 X 467)
6/14/19       #2: Changing doors reveals in Cabinet v ...
Sam jackson
Do you have the closet module? If so, reveals are controlled by a UCS and cannot be changed in the section editor. I adjust reveals using the section face adjustments.
Hope that helps!
6/14/19       #3: Changing doors reveals in Cabinet v ...
Maxi Member
In previous CV version that was possible and in this version ( 11) i can still do with cabinets catalogs . I'm sorry but this should be like that .
6/19/19       #4: Changing doors reveals in Cabinet v ...
Sam Jackson
Closets are a different class than cabinets so they follow different rules. There is a hard coded override to the reveals when using the catalog imported from the closet module. As I said, try using the adjustments in the section editor. If that doesn’t work for you, I’d contact PLanit and see if they have a solution for you. We use the closet system daily. Once you get used to it it’s not a big deal. Best of luck!
6/19/19       #6: Changing doors reveals in Cabinet v ...
maxi Member
Yes but with all previous version of Cabinet vision I dint have problem to customize setting except version 11.
    • Cabnetware Support
    • CabinetCRUNCHER
    • The Millwork Studio
