Computer Aided Design
Microvellum Library
12/24/19
Shanjai Member
Hello,
I have a problem with changing the depth of a Wall Top Hinge Cabinet.
How can I update the Microvellum Library?
Maybe you know some forums for Microvellum?
It seems like there is not much out there to help with Microvellum issues unless their e-support which we can't afford
I would appreciate your help.
12/24/19       #2: Microvellum Library ...
Ex-Pat Member
I may be able to help, but I need to know what version you are running.
12/24/19       #3: Microvellum Library ...
Shanjai Member
Thank you for your support,
We are using Microvellum Toolbox OEM 2019 enUS (Toolbox 7).
12/26/19       #4: Microvellum Library ...
Ex-Pat Member
Sorry, we are running v67 - they are very similar but different enough I could hurt you more than help.
1/2/20       #5: Microvellum Library ...
Nathan W Member
Hi Sanjai
Are you looking to change the default depth of that specific product? Whenever I want t change anything in the library I will start a test project first. You can safely edit veriables in the workbook designer(at project level) without fear of messing up the veriables at the template level.
I Like to draw the product in question and then open the woork book designer for that product and follow the formula back to the source in the wizard or globals, than change it there. Keep in mind that more that one product may draw information from that variable.
I would suspect that the veriable you want to change is tied to every upper carcass sub assembly. You may have to at a new veriable in you wizard/global work book and change the formulas of the product to match the new veriable.
When you go to draw your top hinge upper if you right clic on the depth(should be red as its formula driving) , and select show formula it should say something like
=G!Upper_Cabinet_Depth
Open your work book designer and find that veriable in you G work book,
mine reads the following
=IF(ISERROR(W!Upper_Cabinet_Depth),330,W!Upper_Cabinet_Depth)
Open
your W work book and find the veriable, Mine reads the following
=IF(Units=1,13,330)
Do some testing but if you change(in my case) the 330(13") it will affect every upper I try to draw. If you are trying to change the depth of just the flip up uppers you will have to create and define a new veriable, some like, G!Upper_Flipup_Cabinet_Depth, and W!Upper_Flipup_Cabinet_Depth. And Make sure your formulas in the product match these variables and it should work.
3/10/20       #6: Microvellum Library ...
Brian
Yes it would help if we knew the version of Microvellum and version of Library. I just dropped a Top Hinge Upper into a drawing and the depth prompt worked great. To set the depth for a project I would go to Project Properties, then Project Wizard, Select Cabinet Size Defaults and change the Upper depth to what I wanted. This is with version 20.1 and the 50.3 Library but I think it has worked much the same for several years.
8/11/20       #7: Microvellum Library ...
Tim Member
i am using microvellum v67.
i need to relocate the screws for 5 knuckle hinges. door and cabinet. does anyone know how this can be done?
    • Cabnetware Support
    • CabinetCRUNCHER
    • The Millwork Studio
