Computer Aided Design
Cabinet section blocks
10/18/23
FAMDan Member
Website: http://www.firstamericanmillwork.com
Hello, I work for a commercial Cabinets shop, and we would be able to modify our cabinet sections / details in such ways like a wall cabinet to be able to stretch to a new height and as we are stretching it new bore holes for shelf pins would come in line and where a second or third new shelf would show up in this detail. Any help on this would be greatly appreciated.
11/20/23       #3: Cabinet section blocks ...
Brian
If I understand you correctly you want to be able to change the height of a cabinet and have the linebore hole number increase as needed along with the door height dimension and possible add an additional shelf? And up date the drawings? Not an issue. Microvellum.
11/20/23       #4: Cabinet section blocks ...
FAMDan Member
Brian,
Thank for your response but I figure it out in AutoCAD a couple of days ago and I forgot I had this thread in here.
11/22/23       #5: Cabinet section blocks ...
David Wishengrad
Hi Famdan,
I thought I had responded to you a while ago. I must have gotten distracted.
If you are using dynamic blocks with stretch points then that will.work. However, adjusting to sizes of drawer fronts and similar can only be done with a table or percentages. So, if you are using them with percentages then 4 drawer fronts @ 7" each, when the cabinet is stretched 1/8" less it will result in 4 fronts 6 31/32". If you are trying to hold hard 1/16" numbers it won't work like that. There are many option. If you want to about other options then please send me an email through here and I will get back to you.
    • Cabnetware Support
    • CabinetCRUNCHER
    • The Millwork Studio
