Computer Aided Design
CV 11 help
4/5/24
Dan Member
Hi all, could anyone tell me what the below error related to;
Add hanging rail to shelves (line43) type mismatch in library part.
This has started coming up on all the parts I have created and when the part opens it adds a ghost part within the intended part. (See pics, the beige parts are ghost parts) But these ghost parts don’t appear on the nest in s2m
Does anybody have any idea what is going on or how to fix it?
4/9/24       #2: CV 11 help ...
Dylan B
Your UCS called "Add hanging rail to shelves" is trying to set the library part of something it is adding and the type of the library part does not align with the type of what the UCS is adding.
If you no longer use that UCS you can disable it by going to the "User Created Standards" in the utilities tab and click it then toggle the lightbulb icon on the top menu bar.
If you do still need it then you will need to fix the library part so that the types align, hard to say what you would do here without seeing the UCS and library part in question.
4/9/24       #3: CV 11 help ...
David Wishengrad Member
-To focus on runtime type-related issues in C++ that don't involve compile-time type checking but rather lead to runtime errors due to misuse or misunderstanding of types, let's consider scenarios typically involving polymorphism, casting, and memory management. In C++, runtime errors often arise from dynamic type identification, casting gone wrong, or accessing memory through incorrect types.
Misusing dynamic_cast
dynamic_cast is used for safely downcasting and polymorphic class type checks at runtime. It checks if the pointer or reference conversion can be performed safely within an inheritance hierarchy and returns nullptr for pointers (or throws std::bad_cast for references) if the conversion is not possible. Misusing dynamic_cast can lead to runtime errors if the program doesn't correctly check the result of the cast
#include #include class Base { public: virtual void show() { std::cout << "In Base\n"; } }; class Derived: public Base { public: void show() override { std::cout << "In Derived\n"; } void specificFunction() { std::cout << "Derived specific function.\n"; } }; void function(Base* base) { Derived* derived = dynamic_cast(base); if (derived) { derived->specificFunction(); } else { std::cout << "dynamic_cast failed.\n"; } } int main() { Base b; function(&b); // dynamic_cast will fail, leading to a runtime check and a message. return 0; }
Misinterpretation of Data with reinterpret_cast
reinterpret_cast allows conversion of any pointer type to any other pointer type, even if the classes are not related. This can lead to runtime errors if misused, especially when casting between types of different sizes or interpretations.
#include int main() { float a = 5.25; int* b = reinterpret_cast(&a); // Unsafe cast std::cout << *b << std::endl; // Interprets the bits of a float as an int, resulting in undefined behavior. return 0; }
Accessing Deleted Memory
Accessing memory that has been freed or deleted can cause runtime errors. This scenario is common when pointers are not managed correctly, leading to dangling pointers.
#include class MyClass { public: void myFunction() { std::cout << "Function of MyClass.\n"; } }; int main() { MyClass* myObject = new MyClass(); delete myObject; // Object is deleted // Undefined behavior: accessing memory that has been freed myObject->myFunction(); return 0; }
These examples illustrate how runtime issues in C++ can occur due to dynamic casting mistakes, incorrect assumptions about object types, misinterpretation of data types with reinterpret_cast, and accessing invalid memory locations. These scenarios highlight the importance of careful type use and memory management in C++ to avoid runtime errors.
Dylan has some good tips as to what it probably is.
    • The Millwork Studio
    • Cabnetware Support
    • CabinetCRUNCHER
