Computer Aided Design
Alphacam
1/31/25
Shaun Member
We are in the process of replacing the PC in one of our cnc machines. We obtained a new (used) PC from the machine manufacturer that included all programs needed to run the machine with the exception of Alphacam. Does anyone know how to transfer Alphacam from our old PC to our new PC? Or, is there a download available for an older version of Alphacam (V6)?
2/1/25       #2: Alphacam ...
DWishengrad
Either pay them for new license for current or software or you're pretty much out of luck. I've never seen anyone with a similar issue feeling happy about the situation.
2/10/25       #3: Alphacam ...
Pdub Member
He's right. Alphacam seems to think they are different than every other software that is purchased (not leased) in that they won't let you put it on a new PC. It's stupid. It's kind of like purchasing a couch and the manufacturer telling you that you can't take it to your new house after a couple years. I understand not getting updated versions of it but you bought V6, you own it and should be able to use in indefinitely.
A LOT of people are unhappy about this. Check out Vectric instead.
2/13/25       #4: Alphacam ...
John McGinnis Member
Find a replacement for AlphaCam. The whole "you can't put this on another computer" thing is crazy.
2/17/25       #5: Alphacam ...
Joe Pace Member
Website: https://leveldevildash.com/
To transfer Alphacam from your old PC to the new one, you’ll first need to check the software's license transfer process. Contact Alphacam’s support team or your distributor to request a license transfer, as the software typically requires reactivation on a new machine. If you have the original installation files or disks for Alphacam V6, you can try installing it on the new PC, ensuring you also transfer any separate license files. However, older versions like V6 may not be available for direct download, so reaching out to Alphacam support or an authorized distributor would be your best option. They can guide you through the reinstallation or license transfer process to ensure the software works smoothly on your new PC.
2/19/25       #6: Alphacam ...
Elwin Thiel Member
Regarding the download of an older version (V6) of Alphacam, if you don’t have access to the original installation media, it's unlikely that Alphacam will make older versions available for public download.
    • Cabnetware Support
    • CabinetCRUNCHER
    • The Millwork Studio
