Computer Aided Design
Cabinet Ware/Auto Cabinet Software
2/9/22
Scott Member
Hi all,
I am really hoping someone out there can take the time to help me with this problem. I recently bought a cabinet shop from an old timer. He used Cabinet Ware (that is at least 20 years outdated) to draw the kitchens and get door/drawer lists from, then he would transfer them to the AI center. From that program, it is exported to Auto Cabinets, where it is turned into an mpr file and is copied to a thumb drive and taken to the router.
Apparently the Router Cad is corrupted and therefore my router is down. I have had a couple of companies look at the router but they don't support any software, just that everything looks good on the router side. I'm guessing there is an easier way to go about this but this is the way I learned so I don't know any other way. I also use the Zargen/KISS 2 system. I assume new software is able to have inputs into it that accepts that type of system.
Any suggestions or tips on how to get this to work would be greatly appreciated. Also, I am a new company, which means not a lot of money, so a cheaper fix would be great! I'm definitely not opposed to new software to get me out of the 80's.
I am dead in the water and my jobs are backing up. Hopefully I can get this resolved before anyone backs out.
2/10/22       #2: Cabinet Ware/Auto Cabinet Software ...
Jim Diebolt Sponsor - Cabnetware Tech Forum
Website: https://forum.designsbydiebolt.com/viewforum.php?f...
I sent a message to one of my technicians to see if we can help you with this.
2/25/22       #3: Cabinet Ware/Auto Cabinet Software ...
yaakov
last line what do you need?
convert from X to Y ?
if so please explain what x give what you expect Y output will be
thanks
5/13/25       #5: Cabinet Ware/Auto Cabinet Software ...
Steve Member
I feel for you—sounds like a frustrating setup to inherit. Cabinet Ware and Auto Cabinets are seriously outdated, and relying on a chain of legacy software can definitely bottleneck production. You might want to look into more modern, budget-friendly solutions that support your Zargen/KISS 2 system and output MPR files directly. Hope someone here can share a solid workaround or alternative!
    • The Millwork Studio
    • Cabnetware Support
    • CabinetCRUNCHER
