Computer Aided Design
Half round fluted columns
3/25/26
jonathan mahnken
Is it possible to machine a half round fluted column in V Carve Pro
View higher quality, full size image (1280 X 1600)
3/26/26       #2: Half round fluted columns ...
Yes you can use the moulding toolpath with a ballnose bit. You will have to prepare the blank with the mitre under cut with another operation.
3/26/26       #3: Half round fluted columns ...
jonathan mahnken
Thanks tom I would imagine I would need a tapered ballnose?
3/26/26       #4: Half round fluted columns ...
I you are careful of the depth and radius of the flutes on the column my guess is you could run a straight ballnose. There are bits with a 1" dia ball with a 1/2" shank but V-carve doesn't recognise the undercut of the bit.
3/29/26       #5: Half round fluted columns ...
Will Williamson  Member
I wonder, how Osborne Wood Products, feels, about you using, their Artwork ?
4/14/26       #6: Half round fluted columns ...
The better fluting is half of an ellipse. The flute tapers along with the land (between the flutes).
And don't forget the entasis. It ain't a column unless it has entasis.
    • The Millwork Studio
    • Cabnetware Support
    • CabinetCRUNCHER
