SCM Routech: PLC44 Vacuum/Equipment Request -- 2 --
7/22
I am hoping someone can help me with this problem.
I keep getting a PLC44 error when I try to execute a program. I clearly have vacuum pressure as the part is held securely. But the program just hangs up when I press start. It seems like it's waiting for an input.
Any ideas are welcomed!
Thanks in advance.
Richard
7/22 #2: SCM Routech: PLC44 Vacuum/Equipment ...
Try v=0 in the program header somewhere, I think it will run without vacuum that way in Xilog.
7/22 #3: SCM Routech: PLC44 Vacuum/Equipment ...
Sounds like you don't have enough vacuum
7/23 #4: SCM Routech: PLC44 Vacuum/Equipment ...
I will check the V=0 option in the header. I thought V was for the feed rate though?
As far as vacuum I definitely have enough suction. I placed a 6"x 96" strip of MDF on the spoilboard and was unable to move it even with most of the spoilboard uncovered. Also it seems like this error is not a lack of suction error code (there is a specific code for that). Instead it's more like it is waiting for the vacuum to be activated which it has.
Anymore ideas are welcome.
Richard
7/24 #5: SCM Routech: PLC44 Vacuum/Equipment ...
I typically do not work with SCM equipment, but I suspect the culprit is whatever sends the input to the control that you have adequate vacuum.
I would troubleshoot for an electro-mechanical switch that may be faulting.
Hope this helps!
Mark T.
9/14 #6: SCM Routech: PLC44 Vacuum/Equipment ...
Had a similar issue with a morbidelli universal 20. It was a loose wire going from the vac sensor in the table to the cnc controller. It was intermittent until I poked it back in order. Check your schematics, they are the most valuable part of your machine.
9/12 #7: SCM Routech: PLC44 Vacuum/Equipment ...
Website: http://www.qualityfixtures.net
We just got a new Morbidelli n100 and are getting the same problem. Did you find what fixed the issue? Any help or ideas greatly appreciated.
2 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
