Subject: Re: biesse rover 15, boring block spindle motor is connect to yaskawa drive
biesse rover 15, boring block spindle motor is connect to yaskawa driver?
3/22/15
ozan
hi,
Biesse rover 15
I found my boring block spindle motor head gear screw was loose, but all these years i was using it like that and triping the motor circuit and turning back and reseting using like that long time, last two years i burnt resistors yaskawa Z drive twice.
I am not sure is yaskawa Z driver related to boring block motor or is it separate ?
my error mesages are motor overload, so i decided to remove the motor which i am glad, i found screw was loose at spindle head, gear dropped on the block and grinding the block so i cleaned up tight the screw back oiled installed back. When i turn the motor spindle by hand it is tighter and no tilting on the bearings, it was very smooth slightly movement before i tight it back, is that normal?
also i found motor RC filter was crack in the controller cabinet,
so i am waiting the driver from the repair shop few other parts. Is any of you have knowledge?
Oz.
3/23/15       #2: biesse rover 15, boring block spind ...
Mike McClaran
Website: http://www.greenbvc.com
There is no relation to your Z yaskawa drive and the drill block nor the router inverter.
"found motor RC filter was crack". Not sure what you are referring to here. Drill motor? Z motor?
BVC also rebuilds any Biesse drill heads.
