Subject: Re: Biesse Stream B1 [If you don't know what this is, don't bother opening.
Biesse Stream B1 [If you don't know what this is, don't bother opening.]
3/14/16
Johzen Member
Here is a video of the problem https://youtu.be/ivunk-M9s14
I've done these steps:
1) I changed the LCD monitor.
2) I replaced the batteries with new ones.
3) Switch up #s 6 & 8
4) Turned on the power for 2 seconds, then off.
5) Switch #s 6 & 8 back down
6) Turned the power on
7) Checked the statistics, made sure if it's @ 0
8) Input the password "BSUSER"
9) Go to Parameters/Motors, load the motors parameter file from F2. Same goes with Axis, Speed, and Insertion. Exit.
10) Go to Edges, load the edges file. Select desired edges.
11) Ran a data. Turned on the machine, and this happens https://youtu.be/ivunk-M9s14
3/14/16       #2: Biesse Stream B1 [If you don't know ...
cabinetmaker
You will need to check the parameters of timimg ie- is it 300 ?
I do not see you turning the machine off after step 9 for a save.
Are you missing the language conversion ? I do not see it
3/17/16       #3: Biesse Stream B1 [If you don't know ...
Peter Magennis
Website: http://biesseamerica.com
For technical assistance for Biesse Equipment, please call 704-357-3131 and a service ticket will be generated for a prompt call back.
