Subject: Re: Phenolic Countertop feed and speed
4/20/16
Mark
I am going to be cutting 1" phenolic lab tops on a CNC. Not epoxy. Does anyone have a suggestion for tooling, feed rate and RPM?
4/24/16       #2: Phenolic Countertop feed and speed ...
Gary B.
Mark,
Phenolic is tough stuff, but with the right bit it cuts well. I've used a 3/8" 3 flute slow helix chipbreaker from Leuco tools, specifically made for Phonelic. It cut the 3/8" material I was cutting like butter. Not sure I'd try 1" in one pass though. That's a lot of meat. Maybe you can get the same bit configuration in a 1/2" diameter?
I'll have to check when I'm at work, but I think I was running it at 18,000 rpm and 12 meters per minute.
4/25/16       #3: Phenolic Countertop feed and speed ...
Mark
Thanks Gary.
I had some more advice PM'd to be as well, and cut these last week. I wound up using a 1/2 inch Onsrud chipbreaker, 3 flute at 16000 RPM and 480 IPM(19m/min). It worked pretty well in 2 passes. I finished with a 2 flute finisher, (Slow helix upcut) at 16 KRPM and 400 IPM.
I am pretty sure if I had more than 10 pieces to cut I could improve on this some for tool life etc but it got me through.
4/25/16       #4: Phenolic Countertop feed and speed ...
Gary B.
Mark,
Thanks for posting back the answer. It's nice to see threads that result in a definitive answer because we can all reference back to them in the future, when we forget what we used to know. :-)
