Subject: Re: Labelling
Labelling
9/27/16
Hi All
What are my options for having labels either printed and applied or written on the parts by the CNC?
We're at the point where sorting through and applying labels takes almost as much or even more time than cutting the sheet.
Moving the entire nest and sorting and labeling off line is not an option for use at this point.
Sharpie?
Special label head reading a layer?
9/27/16       #2: Labelling ...
Gary Balcom Member
Website: http://www.Atlantacabinet.com
Dropout,
I had to read this line twice:
"sorting through and applying labels takes almost as much or even more time than cutting the sheet".
Are you printing them in the office or something? I'd look into an on demand printer at the machine, if you don't have that already.
9/28/16       #3: Labelling ...
JM
We use KCD with its pen function. We use a 60 degree v-bit to scribe basic info on each part. Each part gets a cabinet number, part identifier, and edgeband info. Parts are scribed in a place so as not to be seen once assembled.
Example,
I 19 LS
Line before the 19 shows which edge to be banded, 19 is the cabinet number, and LS stands for Left Side.
Works very well, but adds a couple minutes per sheet of run time, But we dont have to spend any time applying or removing labels.
The problem with adding labels, even if its automated, you likely still need to spend the time to remove them later.
9/28/16       #4: Labelling ...
Brian
I am looking into a method of applying barcodes at the machine, haven't found what I want yet but someone has to make an option.
9/28/16       #5: Labelling ...
I'll assume that you print @ the machine with a regular label printer (exceedingly fast!) and only print one panel's worth of labels at ta time. That being the case you don't have many labels to put on a panel. In our case we have a moving table machine so most of the table is exposed outside of the guard before the machine finished. That means most of the labels are in place before the machine finished routing. The operator has an image of the panel on screen showing labels for each part. He can print the panel image if he wants to.
9/30/16       #6: Labelling ...
Ken
take a look at this device.
Device
10/2/16       #7: Labelling ...
Dan cook
We use file folder labels which fit on the edge of the panel and are only 5/8" high so they don't get taken off by other panels being slid across them. We put them on the back edge and most of the time they don't need to be removed at all. Been doing it this way for years without problems.
10/6/16       #8: Labelling ...
Les Eversen  Member
Website: http://www.cadcode.com
Hi. Not sure what your overall software/hardware mix is, but CADCode Systems has been doing part labeling both in the office and at the CNC for almost 2 decades (and yes, I'm an employee). You can feed CADCode data with a number of different options, from design software to a spreadsheet. Layout and content options are open-ended, all depending on what's in the data.
10/6/16       #9: Labelling ...
Dan cook
We are switching from cabnetware to cabinetvision and also from a point to point to a nested base CNC router. In CW we had a label program that we used and the saw man would put the label on each part as he was cutting them. What are most of you guys using to do your labeling?
10/7/16       #10: Labelling ...
cabinetmaker
We are using a sharpie at the present time for the cnc operator and the office is writing the cabinet numbers on the optimization sheets
We are looking @ label it right now
