Subject: Re: Static buildup
Static buildup
12/1/16
Is anyone doing anything to reduce or eliminate the static buildup from cutting melamine?
I don't have the issue with MDF or plywood.
12/4/16       #2: Static buildup ...
Gerry W
This used to be a "shocking" problem when unloading parts from our cnc router. Especially in the more dry winter months.You need to have your operators wear a grounding strap on their shoe. Google them. Problem solved for us.
12/4/16       #3: Static buildup ...
Wood Dust
Do you have your dust collection hose grounded ? I assume that your hose isn't grounded and that This should solve it .
Let me know how you resolved this !
12/4/16       #4: Static buildup ...
The metal dust hood is solidly attached to the Z axis assembly. There are plastic fingers that drag over the sheet though. I wonder if that's it.
12/6/16       #5: Static buildup ...
Mark T.
Run good quality ground wire from the metal clamps around your dust hose to the metal dust hood. Can also run from the wire that supports the dust hose to the hood.
Mark T.
