Subject: Re: CNC ROUTING_PLUNGE RATE_AXIAL TOOL ENTRY FEED FOR LAMINATED MDF TOOL DI
CNC ROUTING_PLUNGE RATE_AXIAL TOOL ENTRY FEED FOR LAMINATED MDF TOOL DIA
1/1/17
ANTONY JOHN Member
FOR LAMINATED MDF
TOOL DIA 1S 20MM ,
RPM 1800,
FEED 9000 MM/MIN
IN BIESSE ROVER
THANKING YOU.
View higher quality, full size image (1600 X 1280)
1/2/17       #2: CNC ROUTING_PLUNGE RATE_AXIAL TOOL ...
Assume 18000 RPM, not 1800.
Feed rate seems very slow.
Ramp in at 500 inches per minute will work. Cut at 800 IPM or so.
