Subject: Re: cnc dust collection
cnc dust collection
1/23/17
Wes
Hello, i'm hooking up a cnc which needs a 9" duct and the downdraft at the pushoff which needs a 8" duct. i'm thinking about using Nedarman's s-500 and dedicating it for those two. Has anyone done that? How has it worked?
1/23/17       #2: cnc dust collection ...
Those are great collectors. I can't comment if that is large enough.
You might be able to save a buck by making a system to close gates depending on which is needed which would require less CFM. That is how our CNC is plumbed.
The pusher is likely operated by pneumatic cylinders.
If you make pneumatic gates like the one pictured you can tee into the air for the pusher cylinder so when one gate opens the other closes.
Pusher up, head gate open, downdraft closed
Pusher down, head gate closed, downdraft open
Your cost is a couple aluminum angles, 2 cylinders and some hose and connectors. You might want to put some flow controls on the gates so they don't slam open and closed.
Good luck.
View larger image
1/23/17       #3: cnc dust collection ...
Wes
wow, great idea! thanks!. what are "flow controls"?
1/23/17       #4: cnc dust collection ...
It's just a small valve that limits the flow of air.
flow controls
1/26/17       #5: cnc dust collection ...
Bill, thank you for posting that picture. I just got a pair of cylinders to run the gates on top of my widebelt, and my idea for mounting the cylinders was way more convoluted than what you're showing. You've hit the easy button for me.
