Subject: Re: Biesseworks - Parametric arks
5/17/17
JOHN ALVES Member
I am trying to create some Kitchen doors in Parametric on Biesseworks, however I am having a few issues with this one.
I made a drawing in AutoCAD first to get all my points (see attached pdf) but when I input those points on Biesseworks the arks are in the wrong direction as you can see in the attached picture.
Any ideas what I need to do to fix this?
Thank you.
CITDAL_DOOR_FISH_EYE.pdf
View higher quality, full size image (1366 X 768)
5/17/17       #2: Biesseworks - Parametric arks ...
Wood Dust
Call Biesse direct, they do free phone support. They should be able to help you with all of this no problem.
5/17/17       #3: Biesseworks - Parametric arks ...
There should be a utility to reverse the direction of the line.
You can also do this in Auto Cad, google it.
5/17/17       #4: Biesseworks - Parametric arks ...
John Alves Member
I tried that it didn't work.
5/18/17       #5: Biesseworks - Parametric arks ...
Dan
Did you try changing the solution value on the arc?
5/18/17       #6: Biesseworks - Parametric arks ...
cabinetmaker
Are you breaking up the arc in multiple segments ? Two end points and a center point can sometimes be to little
Some of the older Biesse editors followed the geometric commands and heiracy so heavily, I would be writing code for hours because I couldn't wrap my head around sons of the macros and the editor functions in the prompts
5/23/17       #7: Biesseworks - Parametric arks ...
Jarvis Hamm
Can you send me the files for acad and bpp file and I'll takeep a look at it
Jarvis
5/24/17       #8: Biesseworks - Parametric arks ...
Kevin Member
I agree with Dan. In Biesseworks the arc comands have some choices at the bottom of the window. Try different (DIR), (SOL). I think if you tried a different solution it will rectify your issue.
5/25/17       #9: Biesseworks - Parametric arks ...
ANTONY Member
you can use this lisp file to change polyline direction (cw / ccw) in autocad.
(defun c:rpoly ( / unit mxv v^v transptucs transptwcs 3dplv hplv ohplv lplv olplv splv helv ListClockwise-p
ss cmde i c ch ent l ll clw
(defun unit ( v )
(mapcar '(lambda ( x ) (/ x (distance '(0.0 0.0 0.0) v))) v)
(defun mxv ( m v )
(mapcar '(lambda ( r ) (apply '+ (mapcar '* r v))) m)
(defun v^v ( u v )
(mapcar '(lambda ( n ) (- (* (nth (car n) u) (nth (cadr n) v)) (* (nth (cadr n) u) (nth (car n) v)))) '((1 2) (2 0) (0 1)))
(defun transptucs ( pt p1 p2 p3 / ux uy uz )
(setq uz (unit (v^v (mapcar '- p2 p1) (mapcar '- p3 p1))))
(setq ux (unit (mapcar '- p2 p1)))
(setq uy (unit (mapcar '- p3 p1)))
(mxv (list ux uy uz) (mapcar '- pt p1))
(defun transptwcs ( pt pt1 pt2 pt3 / pt1n pt2n pt3n )
(setq pt1n (transptucs '(0.0 0.0 0.0) pt1 pt2 pt3))
(setq pt2n (transptucs '(1.0 0.0 0.0) pt1 pt2 pt3))
(setq pt3n (transptucs '(0.0 1.0 0.0) pt1 pt2 pt3))
(transptucs pt pt1n pt2n pt3n)
(defun 3dplv ( pl / v vl )
(if (and (eq (cdr (assoc 0 (entget pl))) "POLYLINE") ( : "))
(if (eq c "CCW")
(progn
(initget "UCS OCS")
(setq ch (getkword "\nSet 3DPOLYLINES, SPLINES, HELIXES clockwise viewed from UCS and 2DPOLYLINES viewed from (UCS / OCS) : "))
(if (eq ch "UCS")
(progn
(while (setq ent (ssname ss (setq i (1+ i))))
(cond
( (and (eq (cdr (assoc 0 (entget ent))) "POLYLINE") ( : "))
(if (eq ch "UCS")
(progn
(cond
( (and (eq (cdr (assoc 0 (entget ent))) "POLYLINE") (< 7 (cdr (assoc 70 (entget ent))) 14))
(if (eq (setq clw (ListClockwise-p (mapcar '(lambda ( p ) (trans p 0 1)) (3dplv ent)))) nil)
(progn
(command "_.reverse" ent "")
(if (assoc "3DPOLYLINE" l)
(setq l (subst (cons "3DPOLYLINE" (1+ (cdr (assoc "3DPOLYLINE" l)))) (assoc "3DPOLYLINE" l) l))
(setq l (cons (cons "3DPOLYLINE" 1) l))
(progn
(if (vl-catch-all-error-p clw)
(if (assoc "3DPOLYLINE" ll)
(setq ll (subst (cons "3DPOLYLINE" (1+ (cdr (assoc "3DPOLYLINE" ll)))) (assoc "3DPOLYLINE" ll) ll))
(setq ll (cons (cons "3DPOLYLINE" 1) ll))
( (and (eq (cdr (assoc 0 (entget ent))) "POLYLINE") (< -1 (cdr (assoc 70 (entget ent))) 6))
(if (eq (setq clw (ListClockwise-p (mapcar '(lambda ( p ) (trans p 0 1)) (hplv ent)))) nil)
(progn
(if (assoc "HEAVY2DPOLYLINE" l)
(setq l (subst (cons "HEAVY2DPOLYLINE" (1+ (cdr (assoc "HEAVY2DPOLYLINE" l)))) (assoc "HEAVY2DPOLYLINE" l) l))
(setq l (cons (cons "HEAVY2DPOLYLINE" 1) l))
(progn
(if (assoc "HEAVY2DPOLYLINE" ll)
(setq ll (subst (cons "HEAVY2DPOLYLINE" (1+ (cdr (assoc "HEAVY2DPOLYLINE" ll)))) (assoc "HEAVY2DPOLYLINE" ll) ll))
(setq ll (cons (cons "HEAVY2DPOLYLINE" 1) ll))
( (eq (cdr (assoc 0 (entget ent))) "LWPOLYLINE")
(if (eq (setq clw (ListClockwise-p (mapcar '(lambda ( p ) (trans p 0 1)) (lplv ent)))) nil)
(progn
(if (assoc "LIGHTWEIGHT2DPOLYLINE" l)
(setq l (subst (cons "LIGHTWEIGHT2DPOLYLINE" (1+ (cdr (assoc "LIGHTWEIGHT2DPOLYLINE" l)))) (assoc "LIGHTWEIGHT2DPOLYLINE" l) l))
(setq l (cons (cons "LIGHTWEIGHT2DPOLYLINE" 1) l))
(progn
(if (assoc "LIGHTWEIGHT2DPOLYLINE" ll)
(setq ll (subst (cons "LIGHTWEIGHT2DPOLYLINE" (1+ (cdr (assoc "LIGHTWEIGHT2DPOLYLINE" ll)))) (assoc "LIGHTWEIGHT2DPOLYLINE" ll) ll))
(setq ll (cons (cons "LIGHTWEIGHT2DPOLYLINE" 1) ll))
( (eq (cdr (assoc 0 (entget ent))) "SPLINE")
(if (eq (setq clw (ListClockwise-p (mapcar '(lambda ( p ) (trans p 0 1)) (splv ent)))) nil)
(progn
(if (assoc "SPLINE" l)
(setq l (subst (cons "SPLINE" (1+ (cdr (assoc "SPLINE" l)))) (assoc "SPLINE" l) l))
(setq l (cons (cons "SPLINE" 1) l))
(progn
(if (assoc "SPLINE" ll)
(setq ll (subst (cons "SPLINE" (1+ (cdr (assoc "SPLINE" ll)))) (assoc "SPLINE" ll) ll))
(setq ll (cons (cons "SPLINE" 1) ll))
( (eq (cdr (assoc 0 (entget ent))) "HELIX")
(if (eq (setq clw (ListClockwise-p (mapcar '(lambda ( p ) (trans p 0 1)) (helv ent)))) nil)
(progn
(if (assoc "HELIX" l)
(setq l (subst (cons "HELIX" (1+ (cdr (assoc "HELIX" l)))) (assoc "HELIX" l) l))
(setq l (cons (cons "HELIX" 1) l))
(progn
(if (assoc "HELIX" ll)
(setq ll (subst (cons "HELIX" (1+ (cdr (assoc "HELIX" ll)))) (assoc "HELIX" ll) ll))
(setq ll (cons (cons "HELIX" 1) ll))
(progn
(cond
(progn
(progn
(if (eq (setq clw (ListClockwise-p (ohplv ent))) nil)
(progn
(progn
(if (eq (setq clw (ListClockwise-p (olplv ent))) nil)
(progn
(progn
(progn
(progn
(progn
(progn
(foreach e l
(prompt "\n\nTotal reversement in ") (if (eq c "CCW") (prompt "counter-clock-wise direction of \"") (prompt "clock-wise direction of \"")) (prompt (car e)) (prompt "\" entity(ies) is(are) : ") (princ (itoa (cdr e)))
(prompt "\n")
(foreach e ll
(prompt "\nTotal unknown direction of vertices - no reversement processed of \"") (prompt (car e)) (prompt "\" entity(ies) is(are) : ") (princ (itoa (cdr e)))
(setvar 'cmdecho cmde)
(princ)
(defun c:sclw nil (c:setplsplhelclockw))
