Subject: Re: Phantom Lines
Phantom Lines
11/17/17
Mikaela
Website: http://www.trendwest.ca
When cutting White Oak veneer on K3 the bottom side gets lines in it that match up with the lines in the spoil board. You can't see them when the veneer is still raw - only until we stain it. These phantom lines have to be sanded done with at least 100 grit. I can't understand how the lines of the spoil board would transfer onto the veneer?
11/17/17       #2: Phantom Lines ...
Shouldn't have lines on the spoilboard....
11/17/17       #3: Phantom Lines ...
Johann Huck  Member
Website: http://www.themachinewarehouse.com
Mikeala,
When you are holding down the veneer on the spoil board with vacuum. The veneer is being compressed and not compressed as much where your lines are.
This is the nature of wood. I would recommend either cut the veneer a different way other than on your CNC such as a guillotine or bandsaw.
The only other choice is to sand the panels after cutting on your CNC or make sure the spoilboard is smooth.
Johann Huck
The Machine Warehouse, LLC.
704-839-6615
Johann@tmwsales.com
11/17/17       #4: Phantom Lines ...
Mikaela
Dropout - there is a reason it is called a spoil board......
We fly cut (re-surface) the the spoil board every 30/ 40 sheets.
11/17/17       #5: Phantom Lines ...
I know, I do the same. But when it's really cut, there shouldn't be any lines.
11/20/17       #6: Phantom Lines ...
Pdub
Wow. You must have some serious vacuum hold-down pressure! Can you lessen that in any way and still have enough hold-down for parts? You're the only person I've ever heard of with too MUCH pressure!
11/25/17       #7: Phantom Lines ...
mike
Wow, we all want that vacuum! Maybe you could sand out the ridges on your spoil board after surfacing. Have you tried a different spoil board cutter? I can definitely
see patterns in mine after surfacing, but its nothing you can even feel really.
11/25/17       #8: Phantom Lines ...
Pdub Member
How much do you through cut? In other words, how "deep" are those lines?
