Subject: Re: Solid wood letters
Solid wood letters
3/22/18
TomO Member
Website: http://stgermainscabinet.com
Greetings,
We need to route some 8" high letters in 1" thick solid white oak. At that height the body of the letters are about 1-1/8" wide. I am concerned about failure where the grain is short. I am thinking of laminating (3) 5/16" layers with the center rotated 90°. Kind of against rules but would welcome comments. Thanks
3/22/18       #2: Solid wood letters ...
B.H. Davis Member
I've made solid walnut plywood as you describe but with 1/8" thick layers. That was a successful project but I'd be concerned about trying to do it with 1/4" thick layers.
Whichever thickness you use I'd strongly suggest 1/4 or rift sawn material.
3/22/18       #3: Solid wood letters ...
Paul Miller
I assume these are for interior use. I would try routing solid wood without any special glue up first. That would be a lot less hassle.
When I route wood, I always do a climb cut, running the router clockwise to avoid tear out. Also, for that thickness, I would route it in three passes with the final cut being about an 1/8th of an inch. Less chance of tear out or movement on the table.
3/22/18       #4: Solid wood letters ...
Paul Miller
One thing I should add, I usually route solid wood at about 70 IPM. Not too fast.
3/23/18       #5: Solid wood letters ...
Jared
I'll toss this into the ring also: If your vacuum isn't strong enough to reliably hold small parts or letters as they're routed loose, leave a .030 skin holding them together, then flip the board upside down and run it through your widebelt sander until they come loose. For even smaller parts, you can double-face tape the upside down board onto a sheet of melamine for the ride through the widebelt. I've made parts about pencil eraser size this way, and was surprised at how well it worked. 3M 9832 tape is a must-have for CNC hold-down challenges.
