Subject: Re: Becker vacuum problems
6/27/18
Charlie W Member
I run 2 Becker 2.250 vacumes on my CNC and one of them has gone down. Becker wants me to send them the entire pump... Does anyone know a west coast service person that can troubleshoot this vacuum?
6/27/18       #2: Becker vacuum problems ...
Eric
what do you mean by went down? does it still run but no suction, or does not turn at all?
6/27/18       #3: Becker vacuum problems ...
Charlie W Member
The veins seem to be in spec and the motor turns. But it will not start, it keeps blowing switches.
6/27/18       #4: Becker vacuum problems ...
Eric
Check all three wires singly T1,T2,T3 (all three phases) to the ground wire. Readings should be infinite. If its zero or reads any continuity at all, then a problem exists with either the motor or cable . If it is go directly to the motor and disconnect from cable and check motor and the cable separately
6/27/18       #5: Becker vacuum problems ...
Charlie W Member
We have done all that. The cable and switch are good. There is an internal problem with the motor I believe, perhaps a short or another issue.
6/27/18       #6: Becker vacuum problems ...
Call an electrician or take the unit to a motor shop. Doesn't need to go to Becker.
6/27/18       #7: Becker vacuum problems ...
Eric
I have taken the motor off before, very easy to do. find a electric motor shop and bring it to them. if they cannot fix it you will need a new motor. no need to send it to Becker!
6/27/18       #8: Becker vacuum problems ...
Robb Parker  Member
We have Busch pumps and had one do the same thing. Ditto Eric, pulled motor and took to motor shop. They diagnosed and repaired for about $350. No issues since.
6/27/18       #9: Becker vacuum problems ...
Charlie W Member
Thanks! I'm working on getting my electric motor guy over here. Ill let you know what we find.
