Subject: Re: Disable CID file optimization on Biesse Skill?
6/27/18
daveguru
We have a Biesse Skill Nesting CNC, I have a post for this machine in our ASPAN software which creates a .CID file.
Problem is, I optimize & set machining sequence in ASPAN, when i load the file on the CNC, Biesseworks re-optimizes the file & ruins my sequence/tool strategy!
Can Biesseworks be set to not change the sequence? Or do I need a different ASPAN post? [we have other software which creates a .ISO file for this machine which bypasses biesseworks]
Any help appreciated....
6/28/18       #2: Disable CID file optimization on Bi ...
Dan
You can set this in Biesseworks for each operation you dont want optimized (moved). The variable is (iso) and OPT box should be unchecked.
I'm not sure what the CID line should read but the effect on the vb program is OPT=NO
6/28/18       #3: Disable CID file optimization on Bi ...
daveguru
Thanks Dan
So this is a checkbox in Biesseworks settings screen?
Or something I need to add into the CID file before processing?
We don't run an office version of Biesseworks, & I don't want to edit each file at the machine......
6/28/18       #4: Disable CID file optimization on Bi ...
Dan
The check box referred to is in the individual operation (milling, boring & so on)on the additional data tab.
You could bring that switch in as a variable in the CID.
You can also change optimization types in the settings menu under optimizer tab. You would have to experiment with that a bit. If it is a single program (not a nest) try the "by job list" setting. That may do what you need. If you use that & optimize a nest in Biesseworks it will change tools for every operation in the nest piece by piece. You may want to play a bit with the nesting options if that is the case.
