Subject: Re: mitered joint tip
mitered joint tip
6/28/18
anthonyG Member
Hello all hope your doing great
i need to make a cabinet using double faced particle board melamine and i would like to know if any one did this jobe using a cnc its an 18 mm thickness board
thank you in advance
6/29/18       #2: mitered joint tip ...
Not sure exactly what you're asking...
6/29/18       #3: mitered joint tip ...
Anthony Member
Helo sorry for my bad English
For example i want to make a 8 cm shelf from 1.8 cm melamine boards how can i make the boarder of my shelf like this picture using a cnc (45 degree edge)
I usually use a saw but i got a cnc and i am trying new things
Thank you for ur time
6/29/18       #4: mitered joint tip ...
In my experience trying this with melamine doesn't work well. The paper is too brittle and no matter what you try, the spoil board is never dead flat so the groove is never perfectly even.
6/29/18       #5: mitered joint tip ...
BH Davis  Member
Do some reading here.
Miter folds
7/1/18       #6: mitered joint tip ...
Meter folds for sure but if your sticking with a true miter for us there are simply still some operations that are not best served by the CNC
