Subject: Re: BP100
BP100
7/20/18
Bob  Member
I have an issue with the start up. There are not any errors on the keb. The back stop pins do not come up. air pressure is at 100, vacuum is good. Typically once you hit the start button the pins pop up then you can go to the next step of startup. Called support they wanted to reload PLC tools ?
7/23/18       #2: BP100 ...
Rob
What numeric control is it?
7/23/18       #3: BP100 ...
Bob  Member
NUM ,Type 1040 W , affaire 123637, 1996
7/23/18       #4: BP100 ...
Rob
on the front of the NUM you have 6 led lights L1,L2,L3,Pwr,Halt, and Fail. which leds are on?
7/23/18       #5: BP100 ...
Bob  Member
The only light that is on is power
7/23/18       #6: BP100 ...
Rob
If there were a problem with the logic you would see a fail light on. You cold check in PLCTools -> Tools -> PLC Control then click ON to see what message comes up.
8/18/18       #7: BP100 ...
Bob  Member
Actually what I found was 1 of the router motors did not come up completely. Once I pushed it into place everything was back to normal. Thank you to All for all your assistance !!
Bob
