Subject: Re: Biesse 336 Rover XNC Setup Discs
9/15/18
Paul Member
I have a 1997 Biesse 336 Rover and am needing to reinstall the PLC file from the original setup discs. I recently located the original 3.5 floppy discs (12 total) in our company safe. Needless to say they have not been touched in 21 years. I tried to view them and make a copy on my windows 10 pc but when I try to open them I get a message that the disc has not been formatted and did I want to format it. Obviously I did not format them as I would have lost all files. Is it possible to view these discs from a windows pc ???
9/15/18       #3: Biesse 336 Rover XNC Setup Discs ...
jerry Member
Can you view them on your control computer. Our older Rover runs on Windows 95 and we can view 16 bit files. You may also be able to view them on a linux computer.
9/15/18       #4: Biesse 336 Rover XNC Setup Discs ...
Paul
I have not tried viewing them from my machine yet. I brought them home for the weekend hoping to make a copy of them. I will try viewing them from my rover Monday morning.
9/16/18       #5: Biesse 336 Rover XNC Setup Discs ...
jerry Member
Take extra disks as you could make copies from the Rover
9/16/18       #6: Biesse 336 Rover XNC Setup Discs ...
Paul
Jerry, thanks for the input. Will do. I will post tomorrow evening to let you know how things went.
Paul
9/16/18       #7: Biesse 336 Rover XNC Setup Discs ...
Gerry
I think a unix based OS will have a better chance of making copies of the floppy discs.
Here is a boot screen shot from a 96 Biese Rover that shows it is a Lynx OS
https://en.wikipedia.org/wiki/LynxOS
9/22/18       #8: Biesse 336 Rover XNC Setup Discs ...
Paul
Sorry for the delay in reposting but I had to go out of town for a funeral. Regardless, after trying 5 different times to reinstall the original software I finally got all the disks to read. On each of the prior attempts to reinstall the 9 setup disks, various disks could not be read for whatever reason. Finally on the last time I was able to reach the setup complete screen. Then after looking through all of my backup disks for 21 years I was able to locate the machine data from 2004. After reloading the dati, cicli, and conf files I was finally back to the original setup which eliminated the problem that I was having. I then took the hard drive and had it cloned on 3 other hard drives. Needless to say I learned an invaluable lesson. I now have taken numerous steps to give myself much redundancy. Even though my machine is somewhat ancient compared to today’s technology, I still find myself learning things even after being with the machine for 21 years. Russ at Biesse (who incidentally installed the machine in 97) provided invaluable knowledge. I am going to hate to see him retire when the time comes. The only other tech that I know of that understands the older machines is Rick T. who is also a top notch tech himself. Take care of your older Biesse machines guys because they are getting harder and harder to support. I am so thankful to Russ, Rick, and Biesse for supporting their customers and machines. This post, and problem is officially resolved. Thanks for the input from the other members of this site.
Paul
