Subject: Re: Biesse Works
Biesse Works
9/24/18
Frank Fuzzell Member
We can access our CNC computer remotely using Outlook 365.
Our problem is we can't run the CNC at the same time that we are programming.
Does Biesse Works have the ability to have additional "seats" so that two people can work with it at the same time?
9/24/18       #2: Biesse Works ...
Dan
Yes. We prep files with the office copy and load with a memory stick.
It was not highly recommended that the programming be done remotely. Too many issues with security & safety.
9/25/18       #3: Biesse Works ...
so we should be able to program on the office copy at the same time the CNC is running. I guess when they installed they never set up the office copy.
10/2/18       #4: Biesse Works ...
Randy Member
Office networked to machine.
no stick needed
10/2/18       #5: Biesse Works ...
katz
i dont know how office 365 remote method
but with team-viewer there no any problem to remote and run the machine
about office
if you have the advance dungle then you will have big problem to program in office
unless you"play" with the dungle and move from here to there...
without dungle ,no pocket no simolation no aditional side...
