Subject: Re: How to cut Aluminum Composite Panels?
3/21/19
William Member
Website: http://www.stylecnc.com
Do you know how to cut Aluminum Composite Panels, what machine can cut Aluminum Composite Panels? from STYLECNC, i get the answer. STYLECNC CNC router machine can be used for cutting aluminum plate, aluminum sheet, aluminum parts with high speed and high accuracy. Now the best CNC router for aluminum on sale with affordable price.
View larger image
https://www.youtube.com/watch?v=HLjDI-FJhqU
3/21/19       #2: How to cut Aluminum Composite Panel ...
jerry Member
Most any CNC will cut ACP
5/29/19       #3: How to cut Aluminum Composite Panel ...
Travis Hanley Member
This can be cut on most any router. Tooling makes the difference. I used a 1/2 single flute from Onsrud.
18000 rpm at 600 in/min.
Chip load was around .01
Run the calculations as it has been almost 10 yrs since I programed for cutting ACP.
Single flute was the best by far. It allowed for great chip evacuation.
No coolant
We couldn't contaminate the honeycomb core.
11/19/19       #4: How to cut Aluminum Composite Panel ...
Leo Yan  Member
When you cut aluminum, you need to remove the chips fast, so one or two flute solid carbide upcut router bits are good choices for fast remove of chips.
Solid carbide, single flute upcut router bits are specially designed for aluminum or aluminum composite panels milling.
