Subject: Re: SCM "Time Out Can Open" error - a lot.
9/3/19
Pdub
Our Pratix S15 has thrown this code from time to time since we got it. It wasn't frequently, so we just shut the machine down to reset it and move on. However, it's doing it almost every sheet we run lately.
I remember asking a tech about it (back when it was in warranty) and he said something like we would need to drive a ground rod down 20-30 ft and connect it to fix the problem.
That doesn't seem right. Anyone have another idea?
9/3/19       #2: SCM "Time Out Can Open" e ...
25 to 30 feet seems odd.
2 or 3 makes much more sense.
9/3/19       #3: SCM "Time Out Can Open" e ...
jerry Member
And you could pour some water along side the ground rod to help
9/3/19       #4: SCM "Time Out Can Open" e ...
I've also seen a ground strap attached to the water line coming in to the building - assuming it's copper.
9/3/19       #5: SCM "Time Out Can Open" e ...
Chris
A ground rod isnt the issue as long you have a wired ground going back to he electric panel. I believe you have a can bus splitter going to the kvara, which are known for going bad. I would also check all cam bus lines which are like purple going to each node and making sure they are tight.
9/3/19       #6: SCM "Time Out Can Open" e ...
cabinetmaker
Before you get to crazy, call an electrician and the utility company, and check that the power in and out of the facility has all lugs tightened to torque settings
Make sure the box supplying the machine has the ground isolated and not bonded to the neutral.
Check all electrical connections to avoid all possible loose connections. Make absolutely sure the ground are in a buss bar or tied off to each other.
We recently had an issue with the dust collector vfd shutting down and throwing out the error, ground fault. Upon further inspection, we come to realize a hole in the pipe work was causing excess build up on the motor of dust and a loose fitting was causing static electricity, hence the vfd picked it up.
After 20 minutes of repairs the vfd is happy and the dust collection is better.
Don’t under estimate the basics. And, yes electrical connections should be a routine maintenance log operation, inspected quarterly just like wiping down the tool holders or greasing the hsk spindle fingers
9/4/19       #7: SCM "Time Out Can Open" e ...
Pdub
Thanks All. I'm feeling like it's not the ground.
We were instructed to check the "purple cable" before and do that when it acts up. Sometimes it seems to help, other times not. I'm thinking of spraying some Deoxit in all of those.
I called SCM about it again and the tech is having me look at what I believe might be the bus splitter the next time it acts up to see what the lights are showing. Hopefully that will shed some light.
